Ana içeriğe geç
CHUWI GemiBook XPro SSD Replacement
Neye ihtiyacın var
  1. CHUWI GemiBook XPro SSD Replacement, Battery: adım 1, 2 resimden 1. CHUWI GemiBook XPro SSD Replacement, Battery: adım 1, 2 resimden 2.
    • Peel off the black tape on the upper-right side of the motherboard.
  2. CHUWI GemiBook XPro SSD Replacement: adım 2, 2 resimden 1. CHUWI GemiBook XPro SSD Replacement: adım 2, 2 resimden 2.
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  3. CHUWI GemiBook XPro SSD Replacement: adım 3, 3 resimden 1. CHUWI GemiBook XPro SSD Replacement: adım 3, 3 resimden 2. CHUWI GemiBook XPro SSD Replacement: adım 3, 3 resimden 3.
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  4. CHUWI GemiBook XPro SSD Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  5. CHUWI GemiBook XPro SSD Replacement: adım 5, 3 resimden 1. CHUWI GemiBook XPro SSD Replacement: adım 5, 3 resimden 2. CHUWI GemiBook XPro SSD Replacement: adım 5, 3 resimden 3.
    • Lift the battery up and out of the chassis.
  6. CHUWI GemiBook XPro SSD Replacement, SSD: adım 6, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the single 3 mm screw securing the SSD.
  7. CHUWI GemiBook XPro SSD Replacement: adım 7, 3 resimden 1. CHUWI GemiBook XPro SSD Replacement: adım 7, 3 resimden 2. CHUWI GemiBook XPro SSD Replacement: adım 7, 3 resimden 3.
    • Carefully grip and pull the SSD out of its port.
    • Make sure to purchase the correct form factor of the SSD. The CHUWI GemiBook XPro uses 2280 size M.2 SSD.
Sonuç
JakeV
407 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 52
Her zaman: 174
