Ana içeriğe geç
CHUWI GemiBook XPro Screen Replacement
Neye ihtiyacın var
  1. CHUWI GemiBook XPro Screen Replacement, Battery: adım 1, 2 resimden 1. CHUWI GemiBook XPro Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Peel off the black tape on the upper-right side of the motherboard.
  2. CHUWI GemiBook XPro Screen Replacement: adım 2, 2 resimden 1. CHUWI GemiBook XPro Screen Replacement: adım 2, 2 resimden 2.
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  3. CHUWI GemiBook XPro Screen Replacement: adım 3, 3 resimden 1. CHUWI GemiBook XPro Screen Replacement: adım 3, 3 resimden 2. CHUWI GemiBook XPro Screen Replacement: adım 3, 3 resimden 3.
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  4. CHUWI GemiBook XPro Screen Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  5. CHUWI GemiBook XPro Screen Replacement: adım 5, 3 resimden 1. CHUWI GemiBook XPro Screen Replacement: adım 5, 3 resimden 2. CHUWI GemiBook XPro Screen Replacement: adım 5, 3 resimden 3.
    • Lift the battery up and out of the chassis.
  6. CHUWI GemiBook XPro Screen Replacement, Screen: adım 6, 1 resimden 1.
    • Carefully open the device screen side down.
  7. CHUWI GemiBook XPro Screen Replacement: adım 7, 3 resimden 1. CHUWI GemiBook XPro Screen Replacement: adım 7, 3 resimden 2. CHUWI GemiBook XPro Screen Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the four 4.3 mm screws on the left hinge, and the three 4.3 mm screws on the right hinge.
    • Use a Phillips #1 screwdriver to remove one 5.6 mm hinge screw on the lower-right side of the right hinge.
  8. CHUWI GemiBook XPro Screen Replacement: adım 8, 3 resimden 1. CHUWI GemiBook XPro Screen Replacement: adım 8, 3 resimden 2. CHUWI GemiBook XPro Screen Replacement: adım 8, 3 resimden 3.
    • Peel back the black tape near the right hinge.
  9. CHUWI GemiBook XPro Screen Replacement: adım 9, 2 resimden 1. CHUWI GemiBook XPro Screen Replacement: adım 9, 2 resimden 2.
    • Disconnect the display ribbon cable.
  10. CHUWI GemiBook XPro Screen Replacement: adım 10, 2 resimden 1. CHUWI GemiBook XPro Screen Replacement: adım 10, 2 resimden 2.
    • Lift the screen assembly off of the chassis.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Siller
286 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 454
