Ana içeriğe geç
Cable set up
  1. Cable set up, Cable set up: adım 1, 1 resimden 1.
    • Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker).
    • Check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
    • To connect the ground clip, loosen the ground screw and insert the clip. Once clip is secure tighten the screw.
    FixBot'a Sor
    Yorum Ekle
  2. Cable set up: adım 2, 1 resimden 1.
    • Check the voltage selector switch to make sure its set to the proper voltage depending on your geographic location.
    • Voltage selector should be set to 115 V/60 Hz in the U.S., or 230 V/50 Hz in other countries.
    FixBot'a Sor
    Yorum Ekle
  3. Cable set up: adım 3, 1 resimden 1.
    • Insert power cable into socket.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Nikolai
281 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G14
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 1,259
