Ana içeriğe geç
CamPark BM20 Buttons Replacement
Neye ihtiyacın var
  1. CamPark BM20 Buttons Replacement, Battery: adım 1, 3 resimden 1. CamPark BM20 Buttons Replacement, Battery: adım 1, 3 resimden 2. CamPark BM20 Buttons Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the handheld monitor so the back is facing you.
    • Use your fingers to slide the battery cover off to access the battery.
    FixBot'a Sor
    Yorum Ekle
  2. CamPark BM20 Buttons Replacement: adım 2, 2 resimden 1. CamPark BM20 Buttons Replacement: adım 2, 2 resimden 2.
    • Use a spudger or your fingers to unplug the battery cable from the handheld device.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. CamPark BM20 Buttons Replacement, Buttons: adım 3, 3 resimden 1. CamPark BM20 Buttons Replacement, Buttons: adım 3, 3 resimden 2. CamPark BM20 Buttons Replacement, Buttons: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the three 12.7 mm screws from the lower back of the device.
    • Insert the tip of an iFixit opening tool between the front and back casing seams to release the clips securing the two halves.
    • Gently pry apart the handheld unit.
    FixBot'a Sor
    Yorum Ekle
  4. CamPark BM20 Buttons Replacement: adım 4, 3 resimden 1. CamPark BM20 Buttons Replacement: adım 4, 3 resimden 2. CamPark BM20 Buttons Replacement: adım 4, 3 resimden 3.
    • Unplug the speaker cable from the socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. CamPark BM20 Buttons Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the four 6.35 mm screws from the corners of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. CamPark BM20 Buttons Replacement: adım 6, 2 resimden 1. CamPark BM20 Buttons Replacement: adım 6, 2 resimden 2.
    • Remove the motherboard from the front case and set it on the bottom case with the speaker.
    FixBot'a Sor
    Yorum Ekle
  7. CamPark BM20 Buttons Replacement: adım 7, 3 resimden 1. CamPark BM20 Buttons Replacement: adım 7, 3 resimden 2. CamPark BM20 Buttons Replacement: adım 7, 3 resimden 3.
    • Remove the volume and directional buttons from the top cover.
    • The power and speaker buttons cannot be removed without breaking them off.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Subah Shabnam
837 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 26
Her zaman: 212
