Ana içeriğe geç
CandiGirl Roller Skate Wheels Replacement
Neye ihtiyacın var
  1. CandiGirl Roller Skate Wheels Replacement, Wheels: adım 1, 3 resimden 1. CandiGirl Roller Skate Wheels Replacement, Wheels: adım 1, 3 resimden 2. CandiGirl Roller Skate Wheels Replacement, Wheels: adım 1, 3 resimden 3.
    • Use a 13mm wrench to loosen the nuts in the center of the wheel(s) that need to be replaced.
    • Remove the nuts from the axel.
  2. CandiGirl Roller Skate Wheels Replacement: adım 2, 1 resimden 1.
    • Slide the wheel off the axel and check your axel for dirt, grease, or hair.
    • Clean the axel thoroughly.
  3. CandiGirl Roller Skate Wheels Replacement: adım 3, 1 resimden 1.
    • Open your new set of wheels.
    • It is important to note that CandiGirl skates will need CandiGirl wheels because most standard wheels are not made the same and have different sized axels, nuts, and bearings.
  4. CandiGirl Roller Skate Wheels Replacement: adım 4, 1 resimden 1.
    • Check over the new wheels to make sure they don’t have any issues.
  5. CandiGirl Roller Skate Wheels Replacement: adım 5, 3 resimden 1. CandiGirl Roller Skate Wheels Replacement: adım 5, 3 resimden 2. CandiGirl Roller Skate Wheels Replacement: adım 5, 3 resimden 3.
    • Place the wheel on the axel.
    • Thread the nut onto the axel on top of your wheel with your fingers.
  6. CandiGirl Roller Skate Wheels Replacement: adım 6, 3 resimden 1. CandiGirl Roller Skate Wheels Replacement: adım 6, 3 resimden 2. CandiGirl Roller Skate Wheels Replacement: adım 6, 3 resimden 3.
    • Tighten the nut using the 13mm wrench.
    • Do not apply too much torque to the nut, as you may damage the bearings within the wheel.
  7. CandiGirl Roller Skate Wheels Replacement: adım 7, 3 resimden 1. CandiGirl Roller Skate Wheels Replacement: adım 7, 3 resimden 2. CandiGirl Roller Skate Wheels Replacement: adım 7, 3 resimden 3.
    • Once you have it on there tightly, loosen it a little to allows your wheels to roll smoothly and not rub. Test your wheels by spinning them with your finger.
    • Test your wheels by spinning them with your finger.
    • If the wheel wobbles a little on the axel, tighten the nut slightly. If the wheel doesn't spin smoothly, loosen the nut slightly.
Sonuç
This is a simple replacement with very easy-to-follow instructions. If you followed all the steps exactly, you will be skating again in no time!
Glenda Lee
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 695
