Ana içeriğe geç
Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement
Neye ihtiyacın var
  1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Tripod Mount: adım 1, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Tripod Mount: adım 1, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Tripod Mount: adım 1, 3 resimden 3.
    • If possible, try to work in an environment with minimal dust. The goal is to try to avoid dust from getting inside of the lens as much as possible.
    • Loosen the knob on the tripod mount.
    • Rotate the tripod mount counter-clockwise approximately 135 degrees.
    • Pull the tripod mount towards the rear of the lens. If it does not immediately come off, rotate the tripod mount back and forth slightly until it is in the correct position for the tripod mount to detach from the lens.
  2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Prepare to Remove the Lens Mount: adım 2, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Prepare to Remove the Lens Mount: adım 2, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Prepare to Remove the Lens Mount: adım 2, 3 resimden 3.
    • From this point forward, there will be many small screws that must be removed from the lens. Many of the screws will be of different sizes. Please be sure to keep the screws in a safe place and keep track of where each one came from.
    • Unscrew the four Phillips #00 screws around the inner part of the lens mount:
    • Carefully pull up around the inside edge of the back cover (the black plastic piece inside of the lens mount). The cover should be able to pop out without too much force.
    • Gently push the electrical connector away from the lens mount, so that it is resting off of the lens mount.
  3. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Lens Mount & Fixed Barrel: adım 3, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Lens Mount & Fixed Barrel: adım 3, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Lens Mount & Fixed Barrel: adım 3, 3 resimden 3.
    • Unscrew the four JIS #000 screws holding in the metal lens mount.
    • Grab the metal ring directly below the lens mount and pull upwards. It is best to keep the metal ring, the lens mount, the lens mount washer, and the weather seal together as taking them apart is not needed.
    • Next, remove the four Phillips #00 screws around the outside of the fixed barrel assembly.
    • Be sure to remove the screws that are recessed into the lens, and not the screws that are sticking off of the lens (those ones are only for holding the tripod mount onto the lens).
    • Pull the fixed barrel assembly directly upwards.
    • Use caution while removing the fixed barrel. The main PCB assembly sits around the inside of the fixed barrel, so you don't want to push against it while lifting off the fixed barrel.
  4. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Tape Around Main PCB Assembly: adım 4, 1 resimden 1.
    • Steps 4 and 5 involve handling sensitive electronics. Avoid static discharge.
    • Peel up the end of the black tape surrounding the main PCB assembly and very slowly and carefully begin to peel back the tape.
    • Watch out for ribbon cables that the tape may be adhered to. If needed, grab the ribbon cable with a pair of blunt tip tweezers as you peel back the tape.
    • Use extreme care while handling ribbon cables and connectors as they can be easy to damage.
    • Set the tape aside, as it will be placed back during reassembly.
  5. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Disconnect and Remove the Main PCB Assembly: adım 5, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Disconnect and Remove the Main PCB Assembly: adım 5, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Disconnect and Remove the Main PCB Assembly: adım 5, 3 resimden 3.
    • On the far right PCB board, you may notice two adjustment knobs (they are designed to be adjusted using a screw driver). DO NOT mess with these knobs. Doing so will cause the autofocus to not be able to properly focus, and unless you're able to learn how to readjust them, you'd have to get your lens professionally serviced to fix it.
    • Carefully disconnect the 7 ribbon cables from the main PCB boards.
    • iFixit connector guide
    • Unscrew the three Phillips #00 screws holding the PCB boards in place.
    • Pull off the black plastic cover.
    • Carefully pull off and set aside the main PCB boards.
  6. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the IS Lens Assembly: adım 6, 2 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the IS Lens Assembly: adım 6, 2 resimden 2.
    • Unscrew the three silver M2x8mm Phillips #00 screws around the outside edge of the IS lens assembly.
    • Carefully pull the IS lens assembly up and out of the lens. Be careful not to snag any of the ribbon cables.
    • Avoid touching any of the internal lens elements. Your fingers will leave smudges on them. If you touch one by accident, use a microfiber cloth to wipe them off before the lens is reassembled.
  7. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Zoom Ring: adım 7, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Zoom Ring: adım 7, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Zoom Ring: adım 7, 3 resimden 3.
    • Slip a pair of tweezers underneath the rubber zoom grip and work around the grip to get it over the edge of the zoom ring.
    • Continue until the grip is in a position to be able to pull/push it the rest of the way off the lens with your hands.
    • The rubber grip can deteriorate over time and develop cracks or become more delicate. If you notice signs of deterioration, use extra care while removing the grip to avoid breaking it.
    • Remove the two JIS #000 screws that are underneath where the zoom grip was. There is one on each side.
    • Pull the zoom ring straight up and off of the lens.
  8. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Reverse Gears: adım 8, 2 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Reverse Gears: adım 8, 2 resimden 2.
    • Underneath the zoom ring are two metal rings with teeth on one side of them. In between the metal rings are 3 plastic gears. Those gears are referred to as the reverse gears.
    • Remove the two M1.7x3mm JIS #000 screws holding in one of the reverse gears.
    • Use a pair of tweezers to pull off the reverse gear.
    • Repeat the previous 2 instructions to remove the other two reverse gears.
  9. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Gear Ring 1: adım 9, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Gear Ring 1: adım 9, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove Gear Ring 1: adım 9, 3 resimden 3.
    • Gear ring 1 refers to the upper of the two metal rings (the one closest to the rear of the lens).
    • Remove the Phillips #00 screw holding the zoom ribbon cable in place.
    • Remove the two JIS #000 gear limit screws.
    • Rotate the gear ring 1 as far counter-clockwise as you are able to.
    • Be very careful with the zooming brush, as it is very easily damaged. Make sure it does not snag anything and that the pins do not bend!
    • Pull the gear ring up and off of the lens. You may need to wiggle the ring slightly if it is having troubles coming off.
  10. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Intermediate Barrel: adım 10, 2 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Intermediate Barrel: adım 10, 2 resimden 2.
    • Unscrew the five M2x6mm Phillips #00 screws holding the intermediate barrel in place.
    • Pull the intermediate barrel up and off of the lens.
    • Be careful of the 2 ribbon cables inside of the intermediate barrel as you pull it off of the lens. Do not let them snag on anything.
    • Set aside the front portion of the lens (that you removed the intermediate barrel from).
  11. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Broken Zooming Key: adım 11, 2 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Remove the Broken Zooming Key: adım 11, 2 resimden 2.
    • Remove the two Phillips #00 screws holding in the zooming key.
    • Reach inside of the intermediate barrel with your hand and pull out the zooming key.
  12. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Installing the New Zooming Key: adım 12, 2 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Installing the New Zooming Key: adım 12, 2 resimden 2.
    • Reach inside of the intermediate barrel and position the zooming key in place.
    • Screw back in the two Phillips #00 zooming key screws.
  13. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Gear Ring 1: adım 13, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Gear Ring 1: adım 13, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Gear Ring 1: adım 13, 3 resimden 3.
    • Position the gear ring above the intermediate barrel as you have removed the gear ring, otherwise the ring will not fit into place.
    • You may notice that the inside of the gear ring has some nubs, which lines up with indents on the inside of the intermediate barrel.
    • Lower the gear ring onto the intermediate barrel and then rotate the gear ring clockwise until the zoom brush is back over the ribbon cable.
    • Again, be very careful with the zoom brush as to not bend its pins.
    • Screw in the Phillips #00 zoom ribbon cable screw.
    • Screw in the two JIS #000 gear ring limit screws.
  14. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install Reverse Gears: adım 14, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install Reverse Gears: adım 14, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install Reverse Gears: adım 14, 3 resimden 3.
    • Rotate the upper gear ring (the one you just installed) as far clockwise as you can
    • Rotate the lower gear ring as far counter-clockwise as you can.
    • Both of these gear rings must remain in this position while installing the reverse gears or the zoom ring will be misaligned with the zoom mechanics.
    • Insert one of the reverse gears into position, using caution to not move the gear rings.
    • The reverse gears are the 3 plastic gears that go in between the two gear rings.
    • Screw the two M1.7x3mm JIS #000 screws into the reverse gear.
    • Repeat the previous two instructions to install the other 2 reverse gears.
    • You may now move the gear rings to ensure they move smoothly.
  15. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Attach the Intermediate Barrel: adım 15, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Attach the Intermediate Barrel: adım 15, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Attach the Intermediate Barrel: adım 15, 3 resimden 3.
    • Rotate the upper gear ring fully clockwise.
    • Hold the intermediate barrel above the front portion of the lens and feed the 2 long ribbon cables up through the intermediate barrel.
    • Lower the intermediate barrel into place.
    • The zooming key should go into the slot on the front part of the lens.
    • Line up the screw holes on the intermediate barrel and the front of the lens. Also make sure to line up the ribbon cables with the cut outs in bottom of the intermediate barrel.
    • Screw the five M2x6mm Phillips #00 screws into the bottom of the intermediate barrel, locking it onto the front of the lens.
  16. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Zoom Ring: adım 16, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Zoom Ring: adım 16, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Zoom Ring: adım 16, 3 resimden 3.
    • Place the zoom ring into place. The two screw holes should line up with the screw holes on the upper gear ring. The numbers on the zoom ring should be on the side of the lens with the focus window.
    • Screw in the two JIS #000 zoom ring screws.
    • Slide the rubber zoom grip into place.
    • It's okay if the zoom ring has a little bit of play to it at this stage.
  17. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the IS Lens Assembly: adım 17, 2 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the IS Lens Assembly: adım 17, 2 resimden 2.
    • Position the IS lens assembly over the intermediate barrel. The spot that the white cable comes out of the IS assembly should be positioned just left of the focus window.
    • Lower the IS assembly all the way down into the intermediate barrel.
    • The intermediate barrel is slotted in a way so it is impossible to insert the IS assembly in the wrong position. If the IS assembly is not going into the intermediate barrel all the way, it could be because of this.
    • Be very careful with the ribbon cables on the inside of the intermediate barrel. Ensure that they are laying up against the walls of the intermediate barrel as you insert the IS assembly. There should be indents on the inside of the barrel for them to lay up against.
    • Screw in the three M2x8mm Phillips #00 screws to secure the IS assembly into place.
  18. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Main PCB Assembly: adım 18, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Main PCB Assembly: adım 18, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Main PCB Assembly: adım 18, 3 resimden 3.
    • Steps 18 and 19 involve handling sensitive electronics. Avoid static discharge.
    • Position the main PCB assembly into its place, being careful of the ribbon cables.
    • The one ribbon cable next to the white cable should be routed underneath and around the backside of the PCB board.
    • Screw in the two Phillips #00 screws for the left two PCB boards.
    • Position the black plastic cover in place. The hole in the ring on the cover should be lined up with the screw hole of the right most PCB board.
    • Screw in the Phillips #00 screw into right most PCB board, making sure the screw goes through both the PCB board and the plastic cover behind the board.
    • Although there is also a hole in the rectangular part of the plastic cover, the screw does not need to go through that part of the cover.
    • Remember, DO NOT touch the two adjustment knobs which are located on the right most PCB board.
  19. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Connect Ribbon Cables and Install Tape: adım 19, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Connect Ribbon Cables and Install Tape: adım 19, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Connect Ribbon Cables and Install Tape: adım 19, 3 resimden 3.
    • Reconnect all 7 ribbon cables to the main PCB boards.
    • Take the black tape from earlier, and slowly wrap it back around the main PCB assembly.
    • The rectangular plastic cover should lay in between the right most PCB board and the PCB board that hangs off of the assembly.
    • The tape should be wrapped tight enough so all of the ribbon cables are held out of the way of reinstalling the fixed barrel in the next step. However, avoid from wrapping it too tightly where it causes too much pressure on the PCB boards and other components.
  20. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install Fixed Barrel: adım 20, 2 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install Fixed Barrel: adım 20, 2 resimden 2.
    • Lower the fixed barrel over the main PCB assembly, lining up the holes on the side with the holes on the side of the intermediate barrel.
    • The fixed barrel should be oriented so that the "IMAGE STABILIZER" text should be lined up with focus window further down on the lens.
    • Be very careful lowering the fixed barrel so that you do not damage the main PCB assembly or ribbon cables.
    • Screw in the four Phillips #00 screws around the sides of the fixed barrel.
  21. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Lens Mount: adım 21, 3 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Lens Mount: adım 21, 3 resimden 2. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Install the Lens Mount: adım 21, 3 resimden 3.
    • Place the lens mount onto the fixed barrel, lining it up with the screw holes.
    • Note that on the inner part of the lens mount, there are an extra couple of screw holes where the electrical connector is supposed to be screws onto. Ensure those holes are lined up properly.
    • Screw in the four Phillips #00 screws for the lens mount.
    • Snap the electrical connector into place. The connector has a plastic piece that sticks out the side that will fit into one of the small holes in the lens mount.
    • Screw the two JIS #000 screws through the inner part of the lens mount and into the connector.
    • Snap the back cover into place.
    • Screw in the remaining three JIS #000 screws into the side of the lens mount.
  22. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Reattaching the Tripod Mount: adım 22, 2 resimden 1. Canon EF 70-200mm f/2.8L IS USM Zooming Key Replacement, Reattaching the Tripod Mount: adım 22, 2 resimden 2.
    • Slide the tripod mount back onto the lens in the same position as you took it off.
    • If you forgot what position it needed to be in, just rotate the tripod mount while pushing forward until it slides into place.
    • Rotate the tripod mount to its desired position.
    • Tighten down the knob on the tripod mount.
Bitiş Çizgisi
Ekli Belgeler
Zephosk
4.744 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 21
Son 30 gün: 116
Her zaman: 287
