Ana içeriğe geç
Canon EOS 30 Battery Door Replacement
Neye ihtiyacın var
  1. Canon EOS 30 Battery Door Replacement, Front Panel: adım 1, 1 resimden 1.
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Battery Door Replacement: adım 2, 1 resimden 1.
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Battery Door Replacement: adım 3, 1 resimden 1.
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Battery Door Replacement: adım 4, 1 resimden 1.
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 Battery Door Replacement, Bottom Panel: adım 5, 1 resimden 1.
    • Remove seven 4.25 mm black screws on the bottom panel.
  6. Canon EOS 30 Battery Door Replacement: adım 6, 1 resimden 1.
    • Remove the bottom panel.
  7. Canon EOS 30 Battery Door Replacement, Side Panel With Remote Control Socket: adım 7, 1 resimden 1.
    • Remove two 6.5 mm black screws from the panel.
  8. Canon EOS 30 Battery Door Replacement: adım 8, 1 resimden 1.
    • Remove the plastic remote control socket cap by pulling it straight out.
  9. Canon EOS 30 Battery Door Replacement: adım 9, 2 resimden 1. Canon EOS 30 Battery Door Replacement: adım 9, 2 resimden 2.
    • Slide the panel toward the bottom of the camera to remove.
  10. Canon EOS 30 Battery Door Replacement: adım 10, 1 resimden 1.
    • Remove the single 4.8 silver screw from the control socket.
  11. Canon EOS 30 Battery Door Replacement: adım 11, 2 resimden 1. Canon EOS 30 Battery Door Replacement: adım 11, 2 resimden 2.
    • The control socket is now secure by three wires.
    • Desolder connections to replace the remote control socket.
  12. Canon EOS 30 Battery Door Replacement, Top Panel: adım 12, 1 resimden 1.
    • Slide the outer eyepiece upward to remove it.
  13. Canon EOS 30 Battery Door Replacement: adım 13, 1 resimden 1.
    • Remove the two 4.75 mm black screws located on the top of the camera.
  14. Canon EOS 30 Battery Door Replacement: adım 14, 1 resimden 1.
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  15. Canon EOS 30 Battery Door Replacement: adım 15, 2 resimden 1. Canon EOS 30 Battery Door Replacement: adım 15, 2 resimden 2.
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  16. Canon EOS 30 Battery Door Replacement, Grip: adım 16, 1 resimden 1.
    • Remove the two 5.5 mm screws from front of camera.
  17. Canon EOS 30 Battery Door Replacement: adım 17, 1 resimden 1.
    • Remove grip panel.
  18. Canon EOS 30 Battery Door Replacement, Battery Door: adım 18, 1 resimden 1.
    • Remove one black screw from battery door on underside of grip.
  19. Canon EOS 30 Battery Door Replacement: adım 19, 1 resimden 1.
    • Remove battery door.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jackie
257 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G8
5 Üyeler
22 adet Kılavuz yazıldı
1Rehber Yorum
I was able to complete this by going from step 9 to 15. Oddly, I only had one screw to remove in step 15 but the grip piece easily slid out without needing to remove the top of the camera.
Alan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 4,611
