Ana içeriğe geç
Canon EOS 30 Side Panel With Remote Control Socket Replacement
Neye ihtiyacın var
    1. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Front Panel: adım 1, 1 resimden 1.
      • Remove the two 4.8 mm black screws above the lens on the front of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 2, 1 resimden 1.
      • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 3, 1 resimden 1.
      • Remove the 4.8 mm black screw on the left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 4, 1 resimden 1.
      • Remove the front panel by lifting it away from the camera's body.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Bottom Panel: adım 5, 1 resimden 1.
      • Remove seven 4.25 mm black screws on the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 6, 1 resimden 1.
      • Remove the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Side Panel With Remote Control Socket: adım 7, 1 resimden 1.
      • Remove two 6.5 mm black screws from the panel.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 8, 1 resimden 1.
      • Remove the plastic remote control socket cap by pulling it straight out.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 9, 2 resimden 1. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 9, 2 resimden 2.
      • Slide the panel toward the bottom of the camera to remove.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 10, 1 resimden 1.
      • Remove the single 4.8 silver screw from the control socket.
      FixBot'a Sor
      Yorum Ekle
    5. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 11, 2 resimden 1. Canon EOS 30 Side Panel With Remote Control Socket Replacement: adım 11, 2 resimden 2.
      • The control socket is now secure by three wires.
      • Desolder connections to replace the remote control socket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sterling Vinson
314 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G8
5 Üyeler
44 adet Kılavuz yazıldı
3Kılavuz Yorumları
i have this camera and the door that holds the film in will not stay closed because the plastic piece has broken at the release point. Which piece is it that I need to replace?
luederscoupons - Yanıt Paylaş
That's a bit of a bugger. The piece that's broken off is most likely the little "hook" on the "door" (the proper name of this "door" would be "back").
Since this little hook is integral with the back, you'd have to replace the entire back.
If you still have the piece that has broken off, it may be possible to glue it back in place, but you'd have to reinforce it with e.g. a small piece of aluminium sheet cut from a soft drink can or something like that. Use cyanoacrylate glue (otherwise known as "superglue") and make sure the pieces are clean and fit perfectly before applying the glue. You need only a tiny drop.
Flying Dutchman - Yanıt Paylaş
The EOS 30 is a film camera and therefore does not have an A/V Port, since it does neither Audio nor Video. The socket near the bottom on the grip side is for a wired remote control.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 48
Her zaman: 2,471
