Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Canon EOS Rebel T1i Camera Battery Notch Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: adım 1, 2 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: adım 1, 2 resimden 2.
    • Locate the side of camera with the HDMI port.
    • Unscrew the 7mm with a #00 Phillips screw driver.
  2. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 2, 2 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 2, 2 resimden 2.
    • Use your fingers to gently detach the plastic component from the camera
  3. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 3, 3 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 3, 3 resimden 2. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 3, 3 resimden 3.
    • Unscrew the bottom three 4mm screws with a #00 Phillips screwdriver.
  4. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 4, 1 resimden 1.
    • Unscrew the inner 4mm screw with a #00 Phillips screwdriver.
  5. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 5, 2 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 5, 2 resimden 2.
    • Unscrew the top 7mm screw on the right side of the camera.
    • Unscrew the bottom 4 mm screw on the right side of the camera.
  6. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 6, 3 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 6, 3 resimden 2. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 6, 3 resimden 3.
    • Use the plastic opening tool to pry open the entire back panel.
    • Use your fingers to pull off the back panel.
  7. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 7, 3 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 7, 3 resimden 2. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 7, 3 resimden 3.
    • Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
    • Use the pliers (or your fingers) to take off the white notch.
    • There is a spring underneath the battery notch. Do not lose this spring or let it fall off.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jonathan Lin
548 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-41, Maness Spring 2014 Cal Poly, Team 3-41, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G41
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 3,111
