Ana içeriğe geç
Canon EOS Rebel T2i Eyepiece Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T2i Eyepiece Replacement, I/F Terminal Cover: adım 1, 3 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement, I/F Terminal Cover: adım 1, 3 resimden 2. Canon EOS Rebel T2i Eyepiece Replacement, I/F Terminal Cover: adım 1, 3 resimden 3.
    • Before beginning, ensure that the camera is off, and the battery is removed.
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T2i Eyepiece Replacement, Remove the back casing.: adım 2, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement, Remove the back casing.: adım 2, 2 resimden 2.
    • On the left side of the camera, remove the following screw:
    • One M1.7x6.0mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
  3. Canon EOS Rebel T2i Eyepiece Replacement: adım 3, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement: adım 3, 2 resimden 2.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x2.5mm JIS #000 screws
  4. Canon EOS Rebel T2i Eyepiece Replacement, Open the back panel.: adım 4, 3 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement, Open the back panel.: adım 4, 3 resimden 2. Canon EOS Rebel T2i Eyepiece Replacement, Open the back panel.: adım 4, 3 resimden 3.
    • Slide the viewfinder eyepiece vertically upwards.
    • Start to pull the back cover partially off of the camera.
    • Use caution when removing the back cover, there is a ribbon cable that connects the LCD screen to the main PCB board.
    • Disconnect the LCD screen ribbon cable from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Carefully pull out the ribbon cable from its connector using a pair of angled tweezers.
    • Finish pulling the back cover off of the camera body.
  5. Canon EOS Rebel T2i Eyepiece Replacement, Front Cover: adım 5, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement, Front Cover: adım 5, 2 resimden 2.
    • Remove the following screws from the front of the camera:
    • Two M1.7x5.5mm JIS #000 screws
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T2i Eyepiece Replacement: adım 6, 3 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement: adım 6, 3 resimden 2. Canon EOS Rebel T2i Eyepiece Replacement: adım 6, 3 resimden 3.
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
  7. Canon EOS Rebel T2i Eyepiece Replacement, Top Casing: adım 7, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement, Top Casing: adım 7, 2 resimden 2.
    • Remove the screws next to the viewfinder:
    • One M2.0x8.9mm JIS #000 diopter screw
    • Remove the following screws from the top of the camera:
    • One M1.7x2.5mm JIS #000 screw
    • One M1.7x5.0mm Phillips #000 screw
  8. Canon EOS Rebel T2i Eyepiece Replacement: adım 8, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement: adım 8, 2 resimden 2.
    • Disconnect the microphone cable from the main PCB board.
    • Position a flathead 2.5mm screwdriver between the main PCB board connector and the microphone connector.
    • Gently wiggle the flathead screwdriver back and forth until the microphone connector comes free.
    • If you do not have a flathead 2.5mm screwdriver, another similarly sized flathead screwdriver should work.
  9. Canon EOS Rebel T2i Eyepiece Replacement: adım 9, 3 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement: adım 9, 3 resimden 2. Canon EOS Rebel T2i Eyepiece Replacement: adım 9, 3 resimden 3.
    • Locate the ribbon cable which connects the top cover the main PCB board.
    • Use a plastic spudger tool to carefully pry off the connector.
    • Use caution when handling ribbon connectors and their connectors.
    • Take note of where this fiber optic cable connects to the main PCB board.
    • The cable will slide out of the connector when you pull the top cover off. You will need to remember to slide this cable back into the connector with a pair of tweezers when reinstalling the top cover. This cable is crucial for the function of the camera flash.
  10. Canon EOS Rebel T2i Eyepiece Replacement: adım 10, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement: adım 10, 2 resimden 2.
    • Disconnect these two cables connected to the DC PCB board.
    • Use the same method as with removing the microphone cable, except with using a flathead 3.0mm screwdriver.
    • Gently wiggle the flathead screwdriver back and forth until the connectors comes free.
    • If you do not have a flathead 3.0mm screwdriver, another slightly larger flathead screwdriver should work.
    • Gently lift the top cover up and off of the camera body, being careful that the loose cables do not snag on anything.
  11. Canon EOS Rebel T2i Eyepiece Replacement, Eyepiece: adım 11, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement, Eyepiece: adım 11, 2 resimden 2.
    • Remove the red wire that travels across the mirror box.
  12. Canon EOS Rebel T2i Eyepiece Replacement: adım 12, 1 resimden 1.
    • Remove the following screws holding the mirror box in place:
    • Four M1.7x4.5mm Phillips #000 screws
  13. Canon EOS Rebel T2i Eyepiece Replacement: adım 13, 1 resimden 1.
    • Remove three JIS #000 screws to disconnect the ribbon mount assembly
  14. Canon EOS Rebel T2i Eyepiece Replacement: adım 14, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement: adım 14, 2 resimden 2.
    • Now that the top assembly is free, this exposes another screw on the right side of the mirror box.
    • Remove the following screw:
    • One M2.0x4.3mm JIS #000 screw
    • Remove the orange ribbon cable.
  15. Canon EOS Rebel T2i Eyepiece Replacement: adım 15, 1 resimden 1.
    • Remove the viewfinder assembly from the camera. The screws that hold the eyepiece in place are accessible. Remove these three JIS #000 screws from the rear face of the eyepiece. Two screws are located at the bottom and one screw is located on top.
  16. Canon EOS Rebel T2i Eyepiece Replacement: adım 16, 2 resimden 1. Canon EOS Rebel T2i Eyepiece Replacement: adım 16, 2 resimden 2.
    • With the screws removed, the eyepiece can easily be pulled free.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
Jacob Jaskolka
745 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Shastany Spring 2015 UMass Dartmouth, Team 1-1, Shastany Spring 2015 üyesi
UMASSD-SHASTANY-S15S1G1
3 Üyeler
3Kılavuz Yorumları
I used this guide to fix my 600D (Rebel T3i), and it worked like a charm.
The middle lens of my viewfinder had popped out of its plastic holder. it is now back in place, thanks to this guide.
I have added a couple of marker, to make it just that little bit easier to spot the screws and ribbon cables.
Thanks again!
dauffret - Yanıt
I used this guide to fix my 600D, and it also worked like a charm.
The front lens of my viewfinder (the one closest to the eyepiece) has popped out of its plastic holder.
Leo Sauermann - Yanıt
Thank you so much for this guide. The viewfinder lens of my 1100D came loose some days ago and this guide served perfectly.
Just a heads-up to the newbies like me: Take a lot of care with the focusing screen (the one with the focus points printed on it), I tried to clean it and ruined it. Fortunately, the replacement is not expensive, but still, better not touching it with anything.
Martin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 4,960
