Ana içeriğe geç
Canon EOS Rebel T2i Front Cover Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T2i Front Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 1. Canon EOS Rebel T2i Front Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 2. Canon EOS Rebel T2i Front Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 3.
    • Before beginning, ensure that the camera is off, and the battery is removed.
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T2i Front Cover Replacement, Remove the back casing.: adım 2, 2 resimden 1. Canon EOS Rebel T2i Front Cover Replacement, Remove the back casing.: adım 2, 2 resimden 2.
    • On the left side of the camera, remove the following screw:
    • One M1.7x6.0mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
  3. Canon EOS Rebel T2i Front Cover Replacement: adım 3, 2 resimden 1. Canon EOS Rebel T2i Front Cover Replacement: adım 3, 2 resimden 2.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x2.5mm JIS #000 screws
  4. Canon EOS Rebel T2i Front Cover Replacement, Open the back panel.: adım 4, 3 resimden 1. Canon EOS Rebel T2i Front Cover Replacement, Open the back panel.: adım 4, 3 resimden 2. Canon EOS Rebel T2i Front Cover Replacement, Open the back panel.: adım 4, 3 resimden 3.
    • Slide the viewfinder eyepiece vertically upwards.
    • Start to pull the back cover partially off of the camera.
    • Use caution when removing the back cover, there is a ribbon cable that connects the LCD screen to the main PCB board.
    • Disconnect the LCD screen ribbon cable from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Carefully pull out the ribbon cable from its connector using a pair of angled tweezers.
    • Finish pulling the back cover off of the camera body.
  5. Canon EOS Rebel T2i Front Cover Replacement, Front Cover: adım 5, 2 resimden 1. Canon EOS Rebel T2i Front Cover Replacement, Front Cover: adım 5, 2 resimden 2.
    • Remove the following screws from the front of the camera:
    • Two M1.7x5.5mm JIS #000 screws
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T2i Front Cover Replacement: adım 6, 3 resimden 1. Canon EOS Rebel T2i Front Cover Replacement: adım 6, 3 resimden 2. Canon EOS Rebel T2i Front Cover Replacement: adım 6, 3 resimden 3.
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
Sonuç
Ekli Belgeler
Zephosk
4.741 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 38
