Ana içeriğe geç
Canon EOS Rebel T3 SD Card Board Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T3 SD Card Board Replacement, I/F Terminal Cover: adım 1, 3 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement, I/F Terminal Cover: adım 1, 3 resimden 2. Canon EOS Rebel T3 SD Card Board Replacement, I/F Terminal Cover: adım 1, 3 resimden 3.
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T3 SD Card Board Replacement, Back Cover: adım 2, 2 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement, Back Cover: adım 2, 2 resimden 2.
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
  3. Canon EOS Rebel T3 SD Card Board Replacement: adım 3, 2 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement: adım 3, 2 resimden 2.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
  4. Canon EOS Rebel T3 SD Card Board Replacement: adım 4, 3 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement: adım 4, 3 resimden 2. Canon EOS Rebel T3 SD Card Board Replacement: adım 4, 3 resimden 3.
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
  5. Canon EOS Rebel T3 SD Card Board Replacement, Front Cover: adım 5, 1 resimden 1.
    • Remove the following screws on the front of the camera.
    • Two M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T3 SD Card Board Replacement: adım 6, 1 resimden 1.
    • On the bottom of the camera, remove the following screws:
  7. Canon EOS Rebel T3 SD Card Board Replacement: adım 7, 3 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement: adım 7, 3 resimden 2. Canon EOS Rebel T3 SD Card Board Replacement: adım 7, 3 resimden 3.
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
  8. Canon EOS Rebel T3 SD Card Board Replacement, Top Cover: adım 8, 2 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement, Top Cover: adım 8, 2 resimden 2.
    • Push up and slide off the eyepiece.
    • Remove the following screws:
    • Two M1.7x2.5mm JIS #000 screws
    • One M1.7x3.6mm JIS #000 diopter screw
  9. Canon EOS Rebel T3 SD Card Board Replacement: adım 9, 1 resimden 1.
    • Remove the following screws on the top of the camera:
    • One M1.7x2.5mm JIS #000 screw
  10. Canon EOS Rebel T3 SD Card Board Replacement: adım 10, 2 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement: adım 10, 2 resimden 2.
    • Disconnect the microphone cable from the main PCB board.
    • Position a flathead 2.5mm screwdriver between the main PCB board connector and the microphone connector.
    • Gently wiggle the flathead screwdriver back and forth until the microphone connector comes free.
    • If you do not have a flathead 2.5mm screwdriver, another similarly sized flathead screwdriver should work.
  11. Canon EOS Rebel T3 SD Card Board Replacement: adım 11, 3 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement: adım 11, 3 resimden 2. Canon EOS Rebel T3 SD Card Board Replacement: adım 11, 3 resimden 3.
    • Locate the mode dial ribbon cable on the main PCB board.
    • Use a plastic spudger tool to carefully lift up the locking tab.
    • Use caution when handling ribbon connectors and their connectors.
    • Use a pair of angled tweezers to pull the ribbon cable out of the connector.
  12. Canon EOS Rebel T3 SD Card Board Replacement: adım 12, 2 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement: adım 12, 2 resimden 2.
    • Gently lift up the top cover.
    • There are still several cables connecting the top cover to the camera. Be careful to not pull on these cables while lifting up the top cover.
    • Set the top cover down, making sure not to pull on the cables still attached.
  13. Canon EOS Rebel T3 SD Card Board Replacement, Main PCB Board: adım 13, 3 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement, Main PCB Board: adım 13, 3 resimden 2. Canon EOS Rebel T3 SD Card Board Replacement, Main PCB Board: adım 13, 3 resimden 3.
    • Use caution while handling ribbon cables and ribbon cables connects to avoid damaging them.
    • Locate the two ribbon cables on the main PCB board which are marked in the picture.
    • Disconnect the ribbon cables.
    • These ribbon cables features a hole in them which can assist with disconnecting them. Use either a pair of tweezers or another tool with a thin point to pull out the ribbon cables utilizing this hole.
    • Use a plastic spudger tool to carefully push up and disconnect the imaging sensor ribbon cable.
  14. Canon EOS Rebel T3 SD Card Board Replacement: adım 14, 1 resimden 1.
    • Locate the remaining four ribbon cables connected to the main PCB board.
    • Gently push up on the plastic lock tabs to unlock each of the ribbon cable connectors. Be especially careful with the wide lock tab, as it is particularly fragile.
    • Disconnect each ribbon cable from the main PCB board.
    • Use the same method from the previous step to remove these cables.
  15. Canon EOS Rebel T3 SD Card Board Replacement: adım 15, 2 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement: adım 15, 2 resimden 2.
    • Remove the following screws on the main PCB board:
    • Three M1.7x2.5mm Phillips #000 screws
    • Two M1.7x4.5mm Phillips #000 screws
    • Slide off the metal I/F terminal shield.
  16. Canon EOS Rebel T3 SD Card Board Replacement: adım 16, 2 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement: adım 16, 2 resimden 2.
    • Tilt the main PCB board upwards to reveal the remaining cable connection.
    • Grab the two cables going into the connector, grabbing them as close to the connector as you can.
    • Carefully pull the connector straight out.
  17. Canon EOS Rebel T3 SD Card Board Replacement, SD Card Board: adım 17, 2 resimden 1. Canon EOS Rebel T3 SD Card Board Replacement, SD Card Board: adım 17, 2 resimden 2.
    • Peel back the tape holding the SD card board ribbon cable in place.
    • Use a plastic spudger to carefully lift up the ribbon cable locking tab.
    • Disconnect the ribbon cable from the SD card board.
  18. Canon EOS Rebel T3 SD Card Board Replacement: adım 18, 1 resimden 1.
    • Unscrew the three 3.5mm JIS #000 screws holding the SD card board in place.
    • Remove the SD card board from the camera.
Sonuç
Ekli Belgeler
Zephosk
4.558 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
98 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 39
