Giriş
This guide shows you how to replace the tripod socket, incase you damage the threads beyond repair and need to replace the tripod socket plate.
The Phillips #000 screwdriver is marked as an optional tool as you can always use the JIS #000 screwdriver in its place (JIS screwdrivers won't damage Phillips head screws).
Neye ihtiyacın var
Pry open the rubber I/F terminal cap with your finger.
Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
On the left side of the camera, remove the following screw:
One M1.7x4.5mm JIS #000 screw
On the right side, remove the following screws:
One M1.7x5.5mm JIS #000 screw
Carefully lift the back cover partially off of the camera.
Disconnect the right most ribbon cables from the main PCB board.
Use a plastic spudger to lift up the black locking tab.
Pull out the ribbon cable from its connector using a pair of angled tweezers.
Remove the left ribbon cable using the same two steps as with the other ribbon cable.
Remove the following screws on the front of the camera.
Two M1.7x5.5mm JIS #000 screws
On the bottom of the camera, remove the following screws from the tripod socket plate:
Two M2.0x3.5mm JIS #000 screws
Two M2.0x5.0mm Phillips #000 screws
Pull off the tripod socket plate.
