Ana içeriğe geç
Canon EOS Rebel T7i Back Cover Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T7i Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Canon EOS Rebel T7i Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Before beginning, remove the battery and SD card from the camera.
    • Using your thumbs, push up on the eyepiece to remove it.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
  2. Canon EOS Rebel T7i Back Cover Replacement: adım 2, 3 resimden 1. Canon EOS Rebel T7i Back Cover Replacement: adım 2, 3 resimden 2. Canon EOS Rebel T7i Back Cover Replacement: adım 2, 3 resimden 3.
    • Underneath the right I/F terminal cap, remove the following screws:
    • Two M1.7x5.5mm JIS #000 screws
    • On the right side of the camera, remove the following screws:
    • Two M1.7x4.5mm JIS #000 screws
    • On the back of the camera, remove the following screws next to the viewfinder:
    • Two M1.7x5.0mm Phillips #000 screws
  3. Canon EOS Rebel T7i Back Cover Replacement: adım 3, 3 resimden 1. Canon EOS Rebel T7i Back Cover Replacement: adım 3, 3 resimden 2. Canon EOS Rebel T7i Back Cover Replacement: adım 3, 3 resimden 3.
    • On the bottom of the camera, remove the following screws:
    • Four M1.7x5.0mm Phillips #000 screws
    • Using a plastic opening pick, partially peel up the top of the back rubber grip.
    • Carefully begin lifting the back cover up away from the camera body.
    • Do not lift it all the way off. There is still a ribbon cable attaching the back cover to the main PCB board.
    • Using a plastic spudger tool, gently pry off the back cover ribbon cable from the main PCB board.
Sonuç
Ekli Belgeler
Zephosk
4.744 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 61
Her zaman: 103
