Ana içeriğe geç
Canon PIXMA TS3300 Ink Cartridge Replacement
Meghan Reed
Meghan Reed ve 2 diğer katkıda bulunanlar
En son March 20, 2023 tarihinde güncellendi
3 - 5 dakika
Çok kolay
The purpose of this guide is to inform you on how to change the ink in a printer, specifically a Canon PIXMA TS3300. The cartridge compartment is located at the from of the printer under the large Canon logo. The controls for the printer itself, the power button and lights, are located on top of the printer. In order to change the ink, you will need Canon fine cartridges. 245 is for black ink and 246 is for colored ink.
https://ij.manual.canon/ij/webmanual/Man...
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: adım 1, 2 resimden 1. Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: adım 1, 2 resimden 2.
    • Press the power button in the top left corner to turn on the printer.
    • The light next to the button will turn green if the printer is on.
  2. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 2, 2 resimden 1. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 2, 2 resimden 2.
    • Lift the cartridge compartment located in the front of the printer to gain access on the inside of the printer.
    • Allow for the cartridge holder to move into view.
  3. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 3, 2 resimden 1. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 3, 2 resimden 2.
    • The cartridge should be located in the center of the printer.
    • Push down on the cartridge and pull it out.
  4. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 4, 2 resimden 1. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 4, 2 resimden 2.
    • Prepare the new cartridge by peeling off the cover.
  5. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 5, 3 resimden 1. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 5, 3 resimden 2. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 5, 3 resimden 3.
    • Peel off the orange sticker on the left side of the cartridge.
  6. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 6, 2 resimden 1. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 6, 2 resimden 2.
    • Insert the cartridge at an angle to the cartridge holder.
    • Push upward on the cartridge until a clicking sound is heard.
  7. Canon PIXMA TS3300 Ink Cartridge Replacement: adım 7, 1 resimden 1.
    • Close the cartridge compartment cover.
    • The printer should make a sound from the cartridges going back to their resting position.
Sonuç
Allow for the cartridge holder to reposition and you are ready to print!
6 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Hi if I replace the ink cartridge with a refill the printer has an error message E16 which I know means cartridge is out of ink. How do I override this message to keep printing. I have a Canon TS3360. Jenny.
Jenny - Yanıt
My Pixma TS3300 printer is giving an error message E14 since I replaced the empty cartridges with new 245XL and 246XL cartridges. These should be compatible but aren't working. Please help!
Susan Gardner - Yanıt
Alles geht soweit gut, nur wenn ich die gescannten Dokumente wieder ausdrucken möchte tut es nicht sonder geht in den Speicher, von da Versuche ich wiederum auszudrucken, es springt immer in gespeichert zurück.
Charlotte Suhrbier - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 49
Son 30 gün: 276
Her zaman: 20,370
