Ana içeriğe geç
Canon Pixma MP480 Data Port Replacement
Neye ihtiyacın var
    1. Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: adım 1, 2 resimden 1. Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: adım 1, 2 resimden 2.
      • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Canon Pixma MP480 Data Port Replacement: adım 2, 1 resimden 1.
      • Lift up the back cover to remove it.
      • You may need to lift firmly as it requires quite a bit of force.
      FixBot'a Sor
      Yorum Ekle
    3. Canon Pixma MP480 Data Port Replacement: adım 3, 1 resimden 1.
      • Open the front tray.
      FixBot'a Sor
      Yorum Ekle
    4. Canon Pixma MP480 Data Port Replacement: adım 4, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 4, 2 resimden 2.
      • Open the scanner compartment.
      • Make sure the blue lever locks into place to keep the compartment open.
      FixBot'a Sor
      Yorum Ekle
    5. Canon Pixma MP480 Data Port Replacement: adım 5, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 5, 2 resimden 2.
      • Remove the blue lever from its slot by pushing it back and twisting clockwise.
      • Close the scanner compartment and cover.
      FixBot'a Sor
      Yorum Ekle
    6. Canon Pixma MP480 Data Port Replacement: adım 6, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 6, 2 resimden 2.
      • Pry open the side cover with the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    7. Canon Pixma MP480 Data Port Replacement: adım 7, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 7, 2 resimden 2.
      • Flip the printer over so that the bottom of the printer is facing you.
      • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
      FixBot'a Sor
      Yorum Ekle
    8. Canon Pixma MP480 Data Port Replacement: adım 8, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 8, 2 resimden 2.
      • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
      FixBot'a Sor
      Yorum Ekle
    1. Canon Pixma MP480 Data Port Replacement, LCD: adım 9, 2 resimden 1. Canon Pixma MP480 Data Port Replacement, LCD: adım 9, 2 resimden 2.
      • Using the plastic opening tool, pry off the top cover of the LCD assembly.
      • Pry around the front and side edges for the easiest removal.
      FixBot'a Sor
      Yorum Ekle
    2. Canon Pixma MP480 Data Port Replacement: adım 10, 1 resimden 1.
      • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Canon Pixma MP480 Data Port Replacement: adım 11, 1 resimden 1.
      • Gently pull the ribbon cable to remove the LCD completely.
      FixBot'a Sor
      Yorum Ekle
    1. Canon Pixma MP480 Data Port Replacement, Buttons: adım 12, 1 resimden 1.
      • Locate the buttons on the top of the printer.
      FixBot'a Sor
      Yorum Ekle
    2. Canon Pixma MP480 Data Port Replacement: adım 13, 1 resimden 1.
      • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
      FixBot'a Sor
      Yorum Ekle
    3. Canon Pixma MP480 Data Port Replacement: adım 14, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 14, 2 resimden 2.
      • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Canon Pixma MP480 Data Port Replacement: adım 15, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 15, 2 resimden 2.
      • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
      FixBot'a Sor
      Yorum Ekle
    5. Canon Pixma MP480 Data Port Replacement: adım 16, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 16, 2 resimden 2.
      • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Canon Pixma MP480 Data Port Replacement: adım 17, 1 resimden 1.
      • Gently pull the LCD screen up to remove it from its fixture.
      FixBot'a Sor
      Yorum Ekle
    7. Canon Pixma MP480 Data Port Replacement: adım 18, 1 resimden 1.
      • Use the plastic opening tool to pry off the plastic button assembly.
      FixBot'a Sor
      Yorum Ekle
    8. Canon Pixma MP480 Data Port Replacement: adım 19, 1 resimden 1.
      • Gently pull the plastic button assembly up to remove it.
      • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
      FixBot'a Sor
      Yorum Ekle
    9. Canon Pixma MP480 Data Port Replacement: adım 20, 1 resimden 1.
      • Remove the ribbon cable connected to the backside of the plastic button assembly.
      FixBot'a Sor
      Yorum Ekle
    10. Canon Pixma MP480 Data Port Replacement: adım 21, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 21, 2 resimden 2.
      • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    11. Canon Pixma MP480 Data Port Replacement: adım 22, 3 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 22, 3 resimden 2. Canon Pixma MP480 Data Port Replacement: adım 22, 3 resimden 3.
      • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
      • Gently lift the spring and pull the board out of its plastic button assembly.
      FixBot'a Sor
      Yorum Ekle
    12. Canon Pixma MP480 Data Port Replacement: adım 23, 1 resimden 1.
      • Remove the buttons from the plastic button assembly.
      FixBot'a Sor
      Yorum Ekle
    1. Canon Pixma MP480 Data Port Replacement, Data Port: adım 24, 2 resimden 1. Canon Pixma MP480 Data Port Replacement, Data Port: adım 24, 2 resimden 2.
      • Remove the 7.5 mm screw using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Canon Pixma MP480 Data Port Replacement: adım 25, 2 resimden 1. Canon Pixma MP480 Data Port Replacement: adım 25, 2 resimden 2.
      • Remove the five 3.5 mm screws using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Canon Pixma MP480 Data Port Replacement: adım 26, 1 resimden 1.
      • Remove the small plastic clip using the spudger.
      FixBot'a Sor
      Yorum Ekle
    4. Canon Pixma MP480 Data Port Replacement: adım 27, 1 resimden 1.
      • Pull the plastic inserts out of the holes in the top and bottom.
      FixBot'a Sor
      Yorum Ekle
    5. Canon Pixma MP480 Data Port Replacement: adım 28, 1 resimden 1.
      • Remove the board from the printer by pulling the board towards the back of the printer.
      • This requires effort and time as the board comes out slowly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Steven MacLean
86 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-41, Regan Winter 2013 Cal Poly, Team 19-41, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G41
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 2,734
