Ana içeriğe geç
Canon PowerShot A2500 LCD Display Replacement
Neye ihtiyacın var
  1. Canon PowerShot A2500 LCD Display Replacement, Body Casing and Faceplate: adım 1, 2 resimden 1. Canon PowerShot A2500 LCD Display Replacement, Body Casing and Faceplate: adım 1, 2 resimden 2.
    • Remove the knot holding the wrist lanyard onto the camera
  2. Canon PowerShot A2500 LCD Display Replacement: adım 2, 1 resimden 1.
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
  3. Canon PowerShot A2500 LCD Display Replacement: adım 3, 3 resimden 1. Canon PowerShot A2500 LCD Display Replacement: adım 3, 3 resimden 2. Canon PowerShot A2500 LCD Display Replacement: adım 3, 3 resimden 3.
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
  4. Canon PowerShot A2500 LCD Display Replacement: adım 4, 3 resimden 1. Canon PowerShot A2500 LCD Display Replacement: adım 4, 3 resimden 2. Canon PowerShot A2500 LCD Display Replacement: adım 4, 3 resimden 3.
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
  5. Canon PowerShot A2500 LCD Display Replacement, Buttons: adım 5, 1 resimden 1.
    • Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
    • Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
  6. Canon PowerShot A2500 LCD Display Replacement: adım 6, 2 resimden 1. Canon PowerShot A2500 LCD Display Replacement: adım 6, 2 resimden 2.
    • Pull the two clips off located near the power button
    • The clips are easily broken, use care while disconnecting these clips.
  7. Canon PowerShot A2500 LCD Display Replacement: adım 7, 3 resimden 1. Canon PowerShot A2500 LCD Display Replacement: adım 7, 3 resimden 2. Canon PowerShot A2500 LCD Display Replacement: adım 7, 3 resimden 3.
    • Remove the circuit ribbon connecting the flash to the camera in order to proceed to the next instruction.
    • Carefully pull out the circuit ribbon from the camera which should be the last piece holding the button pad onto the camera.
    I feel that this guide is missing a step. The third picture shows the plate behind the buttons lifted off, but not how this is done. It appears to be held in place by a screw on the top of the camera that’s beneath the circuitry that I can’t find mentioned in the guide.
    Shannon Hamilton - Yanıt
    That is certainly true as I had to find out after many tries! Jack
    Jack Banks - Yanıt
  8. Canon PowerShot A2500 LCD Display Replacement, LCD Display: adım 8, 1 resimden 1.
    • Lift the tab at the end of the ribbon
    • Disconnect the ribbon from the circuitboard
Sonuç
Bir başkası bu kılavuzu tamamladı.
Victoria Winters
299 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Duarte Spring 2015 UMass Dartmouth, Team 3-4, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G4
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
There seams to be a step missing on step 6 . As there is a screw that has to be removed covered to the left of button on top of camera.
Jack Banks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 1,374
