Ana içeriğe geç
Canon PowerShot A80 LCD Screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot A80 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  2. Canon PowerShot A80 LCD Screen Replacement: adım 2, 2 resimden 1. Canon PowerShot A80 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
    • To access the second screw, rotate the screen 90° so that it faces upwards.
    FixBot'a Sor
    Yorum Ekle
  3. Canon PowerShot A80 LCD Screen Replacement: adım 3, 3 resimden 1. Canon PowerShot A80 LCD Screen Replacement: adım 3, 3 resimden 2. Canon PowerShot A80 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Gently remove the front and back covers from the screen.
    • Peel back the plastic circuit cover.
    FixBot'a Sor
    Yorum Ekle
  4. Canon PowerShot A80 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Pull the screen away from the base.
    • This will take some force, but remember to handle with care.
    • If a small metal piece between the screen cover and the screen falls out during repair, replace it with the rounded corners facing away from the screen during reassembly.
    FixBot'a Sor
    Yorum Ekle
  5. Canon PowerShot A80 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Unplug the ribbon cable connected to the circuit board latch.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 farklı kişi bu kılavuzu tamamladı.
konrad
220 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011 üyesi
CPSU-REGAN-W11S7G31
6 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Yanıt Paylaş
Do you know where can I find a replacement LCD over internet?
Paolo Gai - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 67
Her zaman: 5,053
