Ana içeriğe geç
Canon PowerShot G3 Zoom Control Spring Replacement
Neye ihtiyacın var
    1. Canon PowerShot G3 Zoom Control Spring Replacement, Zoom Control Spring: adım 1, 1 resimden 1.
      • Start by removing all of the screws around the camera: from the front, back, sides, and bottom.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot G3 Zoom Control Spring Replacement: adım 2, 1 resimden 1.
      • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot G3 Zoom Control Spring Replacement: adım 3, 1 resimden 1.
      • Next remove the front and right side panels (the left side is attached to the front panel).
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot G3 Zoom Control Spring Replacement: adım 4, 1 resimden 1.
      • Finally, remove the top panel as shown.
      FixBot'a Sor
      Yorum Ekle
    5. Canon PowerShot G3 Zoom Control Spring Replacement: adım 5, 3 resimden 1. Canon PowerShot G3 Zoom Control Spring Replacement: adım 5, 3 resimden 2. Canon PowerShot G3 Zoom Control Spring Replacement: adım 5, 3 resimden 3.
      • With the top panel removed, locate the metal plate covering the zoom control on the underside of the panel (located on the forward left side, if the panel is oriented similarly to the first image.) This plate will also be connected to some circuit ribbon. Leave the ribbon attached to the plate.
      • Remove the screws from the plate, and lift and fold the plate along the attached circuit ribbon to the right (as shown in third image.)
      FixBot'a Sor
      Yorum Ekle
    6. Canon PowerShot G3 Zoom Control Spring Replacement: adım 6, 2 resimden 1. Canon PowerShot G3 Zoom Control Spring Replacement: adım 6, 2 resimden 2.
      • With the top panel and metal plate removed, locate the zoom control on the underside of the panel (located on the forward left side if the panel is oriented similarly to the first image.) It will be located directly under the metal plate and circuit ribbon that was removed in the previous step.
      • Once the zoom control is located, remove the faulty zoom control spring from the metal pegs on the panel and zoom control.
      FixBot'a Sor
      Yorum Ekle
    7. Canon PowerShot G3 Zoom Control Spring Replacement: adım 7, 2 resimden 1. Canon PowerShot G3 Zoom Control Spring Replacement: adım 7, 2 resimden 2.
      • Replace the zoom control spring with a comparable spring, attaching the loop ends to the same metal pegs to which the previous spring was attached (on the panel and zoom control.)
      FixBot'a Sor
      Yorum Ekle
Sonuç
Cory Jeanes
101 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 1,090
