Ana içeriğe geç
Canon PowerShot S100 Control Dial Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: adım 1, 3 resimden 1. Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: adım 1, 3 resimden 2. Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: adım 1, 3 resimden 3.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Control Dial Assembly Replacement: adım 2, 1 resimden 1.
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Control Dial Assembly Replacement: adım 3, 3 resimden 1. Canon PowerShot S100 Control Dial Assembly Replacement: adım 3, 3 resimden 2. Canon PowerShot S100 Control Dial Assembly Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
    there is a small hole in the ribbon which the point of the tweezer can hook into to remove the cable.
    macman2 - Yanıt
  4. Canon PowerShot S100 Control Dial Assembly Replacement, Control Dial Assembly: adım 4, 1 resimden 1.
    • Turn the camera over so that the LCD screen is facing you.
    • Remove the screw (3.9mm, Phillips #00) that is attaching the thin metal frame to the camera.
    • Remove the 2 screws (3.1mm, Phillips #00) that are attaching the control dial panel to the camera.
  5. Canon PowerShot S100 Control Dial Assembly Replacement: adım 5, 1 resimden 1.
    • Using the tweezers, detach the ribbon cable that is connected to the dial panel.
  6. Canon PowerShot S100 Control Dial Assembly Replacement: adım 6, 2 resimden 1. Canon PowerShot S100 Control Dial Assembly Replacement: adım 6, 2 resimden 2.
    • Turn the camera over so that the lens is facing you.
    • Using the tweezers, gently lift the flap that is securing the ribbon cable to the motherboard.
    • Using the tweezers, remove the ribbon cable from its socket.
  7. Canon PowerShot S100 Control Dial Assembly Replacement: adım 7, 1 resimden 1.
    • Gently pull the control dial panel, and its attached ribbon cable, through the opening between the top panel and the camera body.
Sonuç
Ricky
968 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Leahy Winter 2015 USF Tampa, Team 1-4, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G4
4 Üyeler
1Rehber Yorum
I have Canon S100 and it was stuck. Can I send this camera to you to get it fixed and if so, what is your address and how much it will cost?
Yeluchuri Paparao - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 1,370
