Giriş
This installation guide will help you remove your broken LCD and install in a new replacement.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Remove the two 2.3mm outer screws.
Remove the two 3.8mm screws near the strap bracket.
Remove small panel covering mounting bracket.
Remove door covering memory card.
Remove the plastic flap covering the motherboard.
Using your fingernail, open the black clip holding the ribbon cable.
Grab the ribbon cable and carefully pull it out of slot.
