Giriş
This guide will show you how to replace the buttons on your Canon Powershot SX150 IS. You can use this guide if any of your buttons no longer work.
Neye ihtiyacın var
Locate the battery cover on the bottom of the camera.
Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
Remove batteries.
Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
Bu adımda kullanılan alet:Tweezers$4.99
Once the back plate is removed. Locate the buttons to the right of the screen.
Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
After lifting the tabs the buttons should come right off, then replace with the new button.
1Rehber Yorum
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
Very useful information and pictures, although with a couple of omissions noted in the comments. (Kind of like getting a recipe from your favorite chef who always seems to leave out one or two of the key ingredients.)
Eventually, if you go slowly, you will get all of the screws out. Just take pictures or make a drawing as you go along so that you know which screws go where when you reassemble. I learned quite a bit about what makes this lens jam and may not have to go quite so deep in to the camera the next time I’m trying to fix a jam.
Phil Smith - Yanıt
