Ana içeriğe geç
Canon PowerShot SX260 HS LCD Screen Replacement
Tyler Kelch
Tyler Kelch ve 4 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
Tahmin yok
Orta
If you need to replace your LCD Screen on your Canon PowerShot SX260 HS this guide is for you!
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 (3 mm) screws on the left side
    • Remove the 2 (3 mm) screws on the bottom of the camera.
    • Remove the 2 (3 mm) screws on the right side of the camera.
  2. Canon PowerShot SX260 HS LCD Screen Replacement: adım 2, 1 resimden 1.
    • Use your plastic opening tool to gently lift and remove back face plate.
    • Unplug the ribbon cable leading to the mode dial.
  3. Canon PowerShot SX260 HS LCD Screen Replacement: adım 3, 1 resimden 1.
    • After removing exterior screws, gently lift off the front face plate with your fingers.
  4. Canon PowerShot SX260 HS LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the 4 (3 mm) screws that are under the face plate.
  5. Canon PowerShot SX260 HS LCD Screen Replacement: adım 5, 1 resimden 1.
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  6. Canon PowerShot SX260 HS LCD Screen Replacement: adım 6, 1 resimden 1.
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  7. Canon PowerShot SX260 HS LCD Screen Replacement: adım 7, 1 resimden 1.
    • Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
    • Gently lift the panel with your fingers.
    • Be careful not to rip the attached yellow ribbon cable.
  8. Canon PowerShot SX260 HS LCD Screen Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully unplug the yellow ribbon cable from the front of the camera using your tweezers.
  9. Canon PowerShot SX260 HS LCD Screen Replacement: adım 9, 1 resimden 1.
    • Gently slide the LCD screen to the right and remove.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyler Kelch
622 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 138
Her zaman: 4,085
