Ana içeriğe geç
Canon PowerShot SX50 HS Flash Bulb Replacement
Neye ihtiyacın var
    1. Canon PowerShot SX50 HS Flash Bulb Replacement, Battery: adım 1, 1 resimden 1.
      • Locate the battery compartment on the bottom of the camera.
      • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 2, 1 resimden 1.
      • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
      • Now remove the battery pack from the camera with your fingers.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SX50 HS Flash Bulb Replacement, Flash Bulb: adım 3, 1 resimden 1.
      • Lift up the flash as you would when using and activating the flash.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 4, 2 resimden 1. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 4, 2 resimden 2.
      • Remove the two Phillips #000 screws, length 3 mm, on both sides of the flash.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 5, 1 resimden 1.
      • Pull off the back encasement of the flash with your fingers. The internals will now become visible.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 6, 2 resimden 1. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 6, 2 resimden 2.
      • Locate the black, white and the beige wires. Desolder these wires at the point of connection with the bulb.
      • See the guide on this link for soldering and desoldering.
      FixBot'a Sor
      Yorum Ekle
    5. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 7, 3 resimden 1. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 7, 3 resimden 2. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 7, 3 resimden 3.
      • Once the wires have been desoldered, pull the flash out of its casing.
      • Remove one end of the rubber band holding the bulb in place.
      • Slide the bulb out of the flash.
      FixBot'a Sor
      Yorum Ekle
    6. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 8, 2 resimden 1. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 8, 2 resimden 2.
      • Completely remove the rubber band from the flash bulb.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Gurrola
273 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-7, Lancaster Spring 2015 Cal Poly, Team 12-7, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G7
5 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
Hello! excellent explanation . Thank you very much! I have a question : could you tell me where I can buy the replacement lamp ? I already tried searching online but can not find anywhere that sells it. Thank you very much , greetings !
German Witt - Yanıt Paylaş
I need a bulb, no one can tell where you can find a bulb, and it says no parts needed. that's stupid since you need a replacement bulb that you can't find. without it all this is useless.
buborek1974 - Yanıt Paylaş
Where can i found the replacement bulb???Why it is written that there is no need for replacement parts?
Audrey - Yanıt Paylaş
Do you know where I can purchase a bulb to go with this type of camera? I can not find just the bulb. Please HELP!
arusso4e - Yanıt Paylaş
Hi, i need know if this piece is the correct
https://es.aliexpress.com/item/328403224...
Thanks
Fredy Cardenas Bolaños - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 42
Her zaman: 6,596
