Ana içeriğe geç
Canon PowerShot SX50 HS Flash Bulb Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX50 HS Flash Bulb Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
  2. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 2, 1 resimden 1.
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
  3. Canon PowerShot SX50 HS Flash Bulb Replacement, Flash Bulb: adım 3, 1 resimden 1.
    • Lift up the flash as you would when using and activating the flash.
  4. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 4, 2 resimden 1. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 4, 2 resimden 2.
    • Remove the two Phillips #000 screws, length 3 mm, on both sides of the flash.
  5. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 5, 1 resimden 1.
    • Pull off the back encasement of the flash with your fingers. The internals will now become visible.
  6. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 6, 2 resimden 1. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 6, 2 resimden 2.
    • Locate the black, white and the beige wires. Desolder these wires at the point of connection with the bulb.
    • See the guide on this link for soldering and desoldering.
  7. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 7, 3 resimden 1. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 7, 3 resimden 2. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 7, 3 resimden 3.
    • Once the wires have been desoldered, pull the flash out of its casing.
    • Remove one end of the rubber band holding the bulb in place.
    • Slide the bulb out of the flash.
  8. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 8, 2 resimden 1. Canon PowerShot SX50 HS Flash Bulb Replacement: adım 8, 2 resimden 2.
    • Completely remove the rubber band from the flash bulb.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Gurrola
267 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-7, Lancaster Spring 2015 Cal Poly, Team 12-7, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G7
5 Üyeler
7 adet Kılavuz yazıldı
5Kılavuz Yorumları
Hello! excellent explanation . Thank you very much! I have a question : could you tell me where I can buy the replacement lamp ? I already tried searching online but can not find anywhere that sells it. Thank you very much , greetings !
German Witt - Yanıt
I need a bulb, no one can tell where you can find a bulb, and it says no parts needed. that's stupid since you need a replacement bulb that you can't find. without it all this is useless.
buborek1974 - Yanıt
Where can i found the replacement bulb???Why it is written that there is no need for replacement parts?
Audrey - Yanıt
Do you know where I can purchase a bulb to go with this type of camera? I can not find just the bulb. Please HELP!
arusso4e - Yanıt
Hi, i need know if this piece is the correct
https://es.aliexpress.com/item/328403224...
Thanks
Fredy Cardenas Bolaños - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 5,963
