Ana içeriğe geç
Canon PowerShot SX520 HS LCD Screen Replacement
Lisa Choe
Lisa Choe ve başka bir katkıda bulunan
En son December 17, 2015 tarihinde güncellendi
5 - 10 dakika
Orta
Eksik Adımlar
Does your screen flicker or simply not turn on? Replacing the LCD screen may solve the problem.
Neye ihtiyacın var
Aletler
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
  1. Canon PowerShot SX520 HS LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS LCD Screen Replacement: adım 2, 1 resimden 1.
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: adım 3, 3 resimden 1. Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: adım 3, 3 resimden 2. Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: adım 3, 3 resimden 3.
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS LCD Screen Replacement: adım 5, 2 resimden 1. Canon PowerShot SX520 HS LCD Screen Replacement: adım 5, 2 resimden 2.
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS LCD Screen Replacement: adım 6, 1 resimden 1.
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS LCD Screen Replacement, LCD Screen: adım 7, 1 resimden 1.
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS LCD Screen Replacement: adım 8, 1 resimden 1.
    • Carefully pop out the LCD screen with your fingers.
Sonuç
Lisa Choe
460 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-4, Williams Fall 2015 Baylor, Team 4-4, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S4G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 969
