Ana içeriğe geç
Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: adım 1, 3 resimden 1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: adım 1, 3 resimden 2. Canon Powershot ELPH 100 HS Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: adım 2, 2 resimden 1. Canon Powershot ELPH 100 HS Battery Replacement: adım 2, 2 resimden 2.
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lillia
255 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G10
2 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - Yanıt
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 57
Her zaman: 1,788
