Ana içeriğe geç
Canon Powershot ELPH 100 HS Speaker Replacement
Neye ihtiyacın var
  1. Canon Powershot ELPH 100 HS Speaker Replacement, Battery: adım 1, 3 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement, Battery: adım 1, 3 resimden 2. Canon Powershot ELPH 100 HS Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Speaker Replacement: adım 2, 2 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 2, 2 resimden 2.
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Speaker Replacement, Memory Card: adım 3, 3 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement, Memory Card: adım 3, 3 resimden 2. Canon Powershot ELPH 100 HS Speaker Replacement, Memory Card: adım 3, 3 resimden 3.
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
  4. Canon Powershot ELPH 100 HS Speaker Replacement, Outer Case: adım 4, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  5. Canon Powershot ELPH 100 HS Speaker Replacement: adım 5, 1 resimden 1.
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  6. Canon Powershot ELPH 100 HS Speaker Replacement: adım 6, 2 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 6, 2 resimden 2.
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  7. Canon Powershot ELPH 100 HS Speaker Replacement: adım 7, 2 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 7, 2 resimden 2.
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  8. Canon Powershot ELPH 100 HS Speaker Replacement: adım 8, 2 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 8, 2 resimden 2.
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  9. Canon Powershot ELPH 100 HS Speaker Replacement: adım 9, 1 resimden 1.
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  10. Canon Powershot ELPH 100 HS Speaker Replacement: adım 10, 3 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 10, 3 resimden 2. Canon Powershot ELPH 100 HS Speaker Replacement: adım 10, 3 resimden 3.
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
  11. Canon Powershot ELPH 100 HS Speaker Replacement, Speaker: adım 11, 1 resimden 1.
    • Turn on soldering Iron.
  12. Canon Powershot ELPH 100 HS Speaker Replacement: adım 12, 3 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 12, 3 resimden 2. Canon Powershot ELPH 100 HS Speaker Replacement: adım 12, 3 resimden 3.
    • Gently remove the tabs surrounding the power button on the housing of the camera.
    • Be careful not to break the wires that connect the housing to the body of the camera.
  13. Canon Powershot ELPH 100 HS Speaker Replacement: adım 13, 1 resimden 1.
    • Make sure the battery is removed.
    • Cut the wires half way between the microphone and body of camera.
    • Leave 25mm of wire on the speaker when cutting the wire
  14. Canon Powershot ELPH 100 HS Speaker Replacement: adım 14, 1 resimden 1.
    • Strip the ends of the newly cut wires.
    • Expose only 2 mm of bare wire.
  15. Canon Powershot ELPH 100 HS Speaker Replacement: adım 15, 3 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 15, 3 resimden 2. Canon Powershot ELPH 100 HS Speaker Replacement: adım 15, 3 resimden 3.
    • Remove the 3.1mm screw holding speaker to the housing.
    • Remove the two clips and the metal cover will be released
    • When you remove the metal cover the spring will shoot out.
    • Take note of the spring and its orientation, it will need to be re-installed later
    • Image of the spring
  16. Canon Powershot ELPH 100 HS Speaker Replacement: adım 16, 2 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 16, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, grab the wires to pull the speaker from the plastic housing.
    • Use force as the speaker is glued to the housing.
  17. Canon Powershot ELPH 100 HS Speaker Replacement: adım 17, 1 resimden 1.
    • Test the heat of the soldering iron by touching it to the tip of a paperclip.
    • If the tip of the paperclip melts, the iron should be ready.
    • If you have never used a soldering iron before, please consult the tutorial in the description of this guide, or watch the following video: How To Solder Or Soldering Techniques.
  18. Canon Powershot ELPH 100 HS Speaker Replacement: adım 18, 1 resimden 1.
    • Solder the red wire to the right terminal, and the black wire to the left terminal.
    • Do not apply force to the speaker wires during this step. If the wires break, you will need to re-solder them.
  19. Canon Powershot ELPH 100 HS Speaker Replacement: adım 19, 1 resimden 1.
    • Place the speaker back in it's housing.
  20. Canon Powershot ELPH 100 HS Speaker Replacement: adım 20, 1 resimden 1.
    • Place the metal cover over the speaker.
    • Do not attach the screw.
  21. Canon Powershot ELPH 100 HS Speaker Replacement: adım 21, 2 resimden 1. Canon Powershot ELPH 100 HS Speaker Replacement: adım 21, 2 resimden 2.
    • Lift up the corner of the metal cover and slide the spring in so it rests around the screw hole.
    • After the spring is around the screw hole post, replace the screw so that the cover stays in place.
  22. Canon Powershot ELPH 100 HS Speaker Replacement: adım 22, 1 resimden 1.
    • To reattach the speaker housing to the rest of the camera, make sure the pins and clips are aligned.
Sonuç
To reassemble your device, follow the case disassembly guide in reverse.
2 farklı kişi bu kılavuzu tamamladı.
Jacob
570 İtibar
3 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G10
2 Üyeler
5 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 852
