Ana içeriğe geç
Canon Powershot Pro1 Lens Replacement
Neye ihtiyacın var
  1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: adım 1, 2 resimden 1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: adım 1, 2 resimden 2.
    • Have the lens of the camera facing upwards.
    • Find the red plastic ring.
    • Look for two small opening above the red plastic ring.
    • Reference to the left of the picture and you will see the orange square.
  2. Canon Powershot Pro1 Lens Replacement: adım 2, 3 resimden 1. Canon Powershot Pro1 Lens Replacement: adım 2, 3 resimden 2. Canon Powershot Pro1 Lens Replacement: adım 2, 3 resimden 3.
    • Remove the plastic ring that has a red strip.
    • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
  3. Canon Powershot Pro1 Lens Replacement: adım 3, 3 resimden 1. Canon Powershot Pro1 Lens Replacement: adım 3, 3 resimden 2. Canon Powershot Pro1 Lens Replacement: adım 3, 3 resimden 3.
    • Place the camera on its back with the lens facing upwards as shown in the image
    • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
    • Remove the screw by turning the Philip driver counterclockwise.
    • By removing the screw, you will be able to remove the cover lens.
  4. Canon Powershot Pro1 Lens Replacement: adım 4, 1 resimden 1.
    • Use the nylon spudger to remove the ring holding the lens in place.
    • Pull gently until the lens ring snaps off.
  5. Canon Powershot Pro1 Lens Replacement: adım 5, 1 resimden 1.
    • Refer to the left-hand pictere to see what the len's ring looks like.
  6. Canon Powershot Pro1 Lens Replacement: adım 6, 3 resimden 1. Canon Powershot Pro1 Lens Replacement: adım 6, 3 resimden 2. Canon Powershot Pro1 Lens Replacement: adım 6, 3 resimden 3.
    • Take out the lens once the plastic ring is removed
    • Hold the outer layer of the lens to not create smudges on it.
    • Replace the lens and follow the instruction in reversed order to reassemble the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Seana Meegan
677 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
Hi, can you do a guide on how to repair the diaphragm?
OTVaL - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 54
Her zaman: 2,989
