Ana içeriğe geç
Canon Powershot SD880 Flash Replacement
Neye ihtiyacın var
    1. Canon Powershot SD880 Flash Replacement, Back Cover: adım 1, 3 resimden 1. Canon Powershot SD880 Flash Replacement, Back Cover: adım 1, 3 resimden 2. Canon Powershot SD880 Flash Replacement, Back Cover: adım 1, 3 resimden 3.
      • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
      • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
      • One screw will be located under the rubber USB flap.
      • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
      • Slowly pull the back cover off of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Canon Powershot SD880 Flash Replacement, Front Cover: adım 2, 3 resimden 1. Canon Powershot SD880 Flash Replacement, Front Cover: adım 2, 3 resimden 2. Canon Powershot SD880 Flash Replacement, Front Cover: adım 2, 3 resimden 3.
      • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
      • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
      • The two screws on the other side of the camera were already removed when the back cover was taken off.
      FixBot'a Sor
      Yorum Ekle
    1. Canon Powershot SD880 Flash Replacement, Top Panel: adım 3, 2 resimden 1. Canon Powershot SD880 Flash Replacement, Top Panel: adım 3, 2 resimden 2.
      • Unplug the green and white plugs that connect the top panel to the top of the logic board.
      • Dislodge the tab above the lens.
      • Dislodge the tab at the back.
      FixBot'a Sor
      Yorum Ekle
    1. Canon Powershot SD880 Flash Replacement, LCD Display: adım 4, 3 resimden 1. Canon Powershot SD880 Flash Replacement, LCD Display: adım 4, 3 resimden 2. Canon Powershot SD880 Flash Replacement, LCD Display: adım 4, 3 resimden 3.
      • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
      • Disconnect the ribbons that connect the screen to the camera.
      • Lift the screen off.
      FixBot'a Sor
      Yorum Ekle
    1. Canon Powershot SD880 Flash Replacement, Flash: adım 5, 3 resimden 1. Canon Powershot SD880 Flash Replacement, Flash: adım 5, 3 resimden 2. Canon Powershot SD880 Flash Replacement, Flash: adım 5, 3 resimden 3.
      • Use caution when removing the flash, as the capacitor may still have a charge.
      • Remove two 1.8 mm screws from the back using a Phillips #0 screwdriver to disconnect the metal guard.
      • To unplug the ribbon at the top of the camera, gently pull it from the plug-in point.
      • Disconnect the white plug from the red and black wires.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Robert Manno
444 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G3
5 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 3,049
