Ana içeriğe geç
Canon Selphy CP1200 Cooling Fan Replacement
Neye ihtiyacın var
  1. Canon Selphy CP1200 Cooling Fan Replacement, LCD/Buttons: adım 1, 1 resimden 1.
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Cooling Fan Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
  5. Canon Selphy CP1200 Cooling Fan Replacement, Motherboard: adım 5, 1 resimden 1.
    • Detach the fan cable from the motherboard.
  6. Canon Selphy CP1200 Cooling Fan Replacement: adım 6, 1 resimden 1.
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Cooling Fan Replacement: adım 7, 1 resimden 1.
    • Unscrew the three 3mm PH000 screws from the motherboard.
  8. Canon Selphy CP1200 Cooling Fan Replacement: adım 8, 1 resimden 1.
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Cooling Fan Replacement: adım 9, 1 resimden 1.
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
  10. Canon Selphy CP1200 Cooling Fan Replacement, Print Mechanism: adım 10, 2 resimden 1. Canon Selphy CP1200 Cooling Fan Replacement, Print Mechanism: adım 10, 2 resimden 2.
    • Open the side door and depress the ink cassette release.
    • Slide out and remove the ink cassette.
  11. Canon Selphy CP1200 Cooling Fan Replacement: adım 11, 1 resimden 1.
    • Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
  12. Canon Selphy CP1200 Cooling Fan Replacement: adım 12, 1 resimden 1.
    • Lift out the print mechanism of the printer case.
  13. Canon Selphy CP1200 Cooling Fan Replacement, Cooling Fan: adım 13, 1 resimden 1.
    • Lift out the back case plate.
  14. Canon Selphy CP1200 Cooling Fan Replacement: adım 14, 2 resimden 1. Canon Selphy CP1200 Cooling Fan Replacement: adım 14, 2 resimden 2.
    • Remove the fan by tilting it forward slightly and then lifting upwards.
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Where can I get a new cooling fan for Selphy 1200
Roy johannessen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 353
