Ana içeriğe geç
Canon Selphy CP720 Cooling Fan Replacement
Neye ihtiyacın var
  1. Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 1. Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Remove the four 8mm Phillips #1 screws from the bottom of the printer.
  2. Canon Selphy CP720 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Gently lift the top half of the printer off its base
    • A data ribbon attaches the two halves, so don't pull hard and keep the two halves close together.
  3. Canon Selphy CP720 Cooling Fan Replacement: adım 3, 3 resimden 1. Canon Selphy CP720 Cooling Fan Replacement: adım 3, 3 resimden 2. Canon Selphy CP720 Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Remove the side panel by lifting it out.
  4. Canon Selphy CP720 Cooling Fan Replacement: adım 4, 2 resimden 1. Canon Selphy CP720 Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port.
    • Do not tug on the wires. Slowly increasing force as you pull is the best way to detach the wires.
  5. Canon Selphy CP720 Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Unscrew the two 8mm Phillips #1 screws from the fan.
    • Remove the fan from the panel.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 373
