Ana içeriğe geç
Canon Selphy CP720 Paper Cassette Replacement
  1. Canon Selphy CP720 Paper Cassette Replacement, Paper Cassette: adım 1, 1 resimden 1.
    • This configuration allows printing but not reloading of the paper cassette. The cassette needs to be removed before paper can be put inside.
  2. Canon Selphy CP720 Paper Cassette Replacement: adım 2, 1 resimden 1.
    • Set the printer on its back so that the Paper Cassette sticks straight up in the air.
    • Pull the Paper Cassette out of the printer. It is guided by two studs that fit into the grooves on the underside of the cassette.
  3. Canon Selphy CP720 Paper Cassette Replacement: adım 3, 1 resimden 1.
    • Slide the translucent top cover of the Paper Cassette back to expose the paper storage area.
    • With the top half pulled back, lift the glossy side and open the Cassette.
  4. Canon Selphy CP720 Paper Cassette Replacement: adım 4, 1 resimden 1.
    • Put no more than 12 pages in the cassette
  5. Canon Selphy CP720 Paper Cassette Replacement: adım 5, 1 resimden 1.
    • Slide the upper clear plastic part back by gripping it on either side and pulling it backward.
  6. Canon Selphy CP720 Paper Cassette Replacement: adım 6, 1 resimden 1.
    • Make sure the metal tab on the printer will fit over base of the cassette to allow the hinged ramp to direct the paper into the rollers.
  7. Canon Selphy CP720 Paper Cassette Replacement: adım 7, 1 resimden 1.
    • Push the cassette into the printer, with the glossy side up. Make sure that the Cassette is being guided by the studs in the mouth of the printer.
Sonuç
There, your Selphy CP720 has been loaded with paper.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 3,623
