Ana içeriğe geç
Canon Selphy CP910 Buttons Replacement
Neye ihtiyacın var
  1. Canon Selphy CP910 Buttons Replacement, Body: adım 1, 2 resimden 1. Canon Selphy CP910 Buttons Replacement, Body: adım 1, 2 resimden 2.
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Buttons Replacement: adım 2, 3 resimden 1. Canon Selphy CP910 Buttons Replacement: adım 2, 3 resimden 2. Canon Selphy CP910 Buttons Replacement: adım 2, 3 resimden 3.
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Buttons Replacement: adım 3, 3 resimden 1. Canon Selphy CP910 Buttons Replacement: adım 3, 3 resimden 2. Canon Selphy CP910 Buttons Replacement: adım 3, 3 resimden 3.
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Buttons Replacement: adım 4, 3 resimden 1. Canon Selphy CP910 Buttons Replacement: adım 4, 3 resimden 2. Canon Selphy CP910 Buttons Replacement: adım 4, 3 resimden 3.
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Buttons Replacement, Buttons: adım 5, 2 resimden 1. Canon Selphy CP910 Buttons Replacement, Buttons: adım 5, 2 resimden 2.
    • Turn the top panel over so the inside faces toward you.
  6. Canon Selphy CP910 Buttons Replacement: adım 6, 3 resimden 1. Canon Selphy CP910 Buttons Replacement: adım 6, 3 resimden 2. Canon Selphy CP910 Buttons Replacement: adım 6, 3 resimden 3.
    • Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
  7. Canon Selphy CP910 Buttons Replacement: adım 7, 2 resimden 1. Canon Selphy CP910 Buttons Replacement: adım 7, 2 resimden 2.
    • Carefully remove the frame attached to the screen.
  8. Canon Selphy CP910 Buttons Replacement: adım 8, 3 resimden 1. Canon Selphy CP910 Buttons Replacement: adım 8, 3 resimden 2. Canon Selphy CP910 Buttons Replacement: adım 8, 3 resimden 3.
    • Take out the circuit board.
    • Once you take out the circuit board, you should be left with just the case.
  9. Canon Selphy CP910 Buttons Replacement: adım 9, 2 resimden 1. Canon Selphy CP910 Buttons Replacement: adım 9, 2 resimden 2.
    • There is a clear plastic “L” shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it.
    • Remove the button framework and replace it with new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christie Peralta
727 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-6, Rose Winter 2016 UW Tacoma, Team 1-6, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 903
