Ana içeriğe geç
Canon Selphy CP910 LCD Screen Replacement
Neye ihtiyacın var
  1. Canon Selphy CP910 LCD Screen Replacement, Body: adım 1, 2 resimden 1. Canon Selphy CP910 LCD Screen Replacement, Body: adım 1, 2 resimden 2.
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 LCD Screen Replacement: adım 2, 3 resimden 1. Canon Selphy CP910 LCD Screen Replacement: adım 2, 3 resimden 2. Canon Selphy CP910 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 LCD Screen Replacement: adım 3, 3 resimden 1. Canon Selphy CP910 LCD Screen Replacement: adım 3, 3 resimden 2. Canon Selphy CP910 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 LCD Screen Replacement: adım 4, 3 resimden 1. Canon Selphy CP910 LCD Screen Replacement: adım 4, 3 resimden 2. Canon Selphy CP910 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 LCD Screen Replacement, LCD Screen: adım 5, 3 resimden 1. Canon Selphy CP910 LCD Screen Replacement, LCD Screen: adım 5, 3 resimden 2. Canon Selphy CP910 LCD Screen Replacement, LCD Screen: adım 5, 3 resimden 3.
    • Once you detach the top, turn the device around.
    • Use the PH0 screw bit to remove the five [size] screws.
  6. Canon Selphy CP910 LCD Screen Replacement: adım 6, 3 resimden 1. Canon Selphy CP910 LCD Screen Replacement: adım 6, 3 resimden 2. Canon Selphy CP910 LCD Screen Replacement: adım 6, 3 resimden 3.
    • Push out the LCD screen from the main case.
    • The screen should slide out freely.
  7. Canon Selphy CP910 LCD Screen Replacement: adım 7, 3 resimden 1. Canon Selphy CP910 LCD Screen Replacement: adım 7, 3 resimden 2. Canon Selphy CP910 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Pull out the rod connecting the LCD screen to the frame.
    • Insert the new screen.
Sonuç
Christie Peralta
727 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-6, Rose Winter 2016 UW Tacoma, Team 1-6, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,303
