Ana içeriğe geç
Canon Selphy CP910 Printer Body Replacement
Neye ihtiyacın var
  1. Canon Selphy CP910 Printer Body Replacement, Body: adım 1, 2 resimden 1. Canon Selphy CP910 Printer Body Replacement, Body: adım 1, 2 resimden 2.
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Printer Body Replacement: adım 2, 3 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 2, 3 resimden 2. Canon Selphy CP910 Printer Body Replacement: adım 2, 3 resimden 3.
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Printer Body Replacement: adım 3, 3 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 3, 3 resimden 2. Canon Selphy CP910 Printer Body Replacement: adım 3, 3 resimden 3.
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Printer Body Replacement: adım 4, 3 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 4, 3 resimden 2. Canon Selphy CP910 Printer Body Replacement: adım 4, 3 resimden 3.
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Printer Body Replacement, Printer Body: adım 5, 2 resimden 1. Canon Selphy CP910 Printer Body Replacement, Printer Body: adım 5, 2 resimden 2.
    • Use the PH1 screw driver to remove the three screws on the motherboard.
  6. Canon Selphy CP910 Printer Body Replacement: adım 6, 2 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 6, 2 resimden 2.
    • Remove the printer.
    • This will prevent the printer from falling out during repair.
  7. Canon Selphy CP910 Printer Body Replacement: adım 7, 3 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 7, 3 resimden 2. Canon Selphy CP910 Printer Body Replacement: adım 7, 3 resimden 3.
    • Remove the output connections.
    • Be careful! Do not pull too hard because the wires might rip.
    • Output connections are located on the corners of the motherboard.
  8. Canon Selphy CP910 Printer Body Replacement: adım 8, 2 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 8, 2 resimden 2.
    • The motherboard is attached to three more ribbon wires.
    • Detach these wires.
    • Be careful not to pull too hard.
  9. Canon Selphy CP910 Printer Body Replacement: adım 9, 2 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 9, 2 resimden 2.
    • Separate the motherboard from the main hard drive.
  10. Canon Selphy CP910 Printer Body Replacement: adım 10, 3 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 10, 3 resimden 2. Canon Selphy CP910 Printer Body Replacement: adım 10, 3 resimden 3.
    • Remove the main hard drive from the printer body.
  11. Canon Selphy CP910 Printer Body Replacement: adım 11, 2 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 11, 2 resimden 2.
    • Gently remove the fan from the body.
    • The fan is glued to the case. When you install it in the new body, use hot glue to secure it in place.
  12. Canon Selphy CP910 Printer Body Replacement: adım 12, 2 resimden 1. Canon Selphy CP910 Printer Body Replacement: adım 12, 2 resimden 2.
    • The empty case will look like this once all the parts are removed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Christie Peralta
727 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-6, Rose Winter 2016 UW Tacoma, Team 1-6, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G6
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Bien conduit par cette marche à suivre, j'ai réussi à démonter la cartouche bloquée suite à un disfonctionnement des photos .
Le remontage était un peu plus difficile suite à la minutie à apporter auprès du peu de place pour la reconnection. Merci.
Joël vanhooren - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 50
Her zaman: 5,133
