Ana içeriğe geç
Carrera Mario Copter Controller Circuit Board Replacement
Neye ihtiyacın var
  1. Carrera Mario Copter Controller Circuit Board Replacement, Controller Circuit Board: adım 1, 1 resimden 1.
    • Flip the controller over so the underside would face up
    • Remove four of 7.1mm screws with a JIS #1 screwdriver
    • Remove two 4.0mm screws located on the handle with the JIS #1screwdriver.
    • Remove two 7.1 mm screws on the small area that stick out from the surface with the JIS #1 screwdriver
    • Use an extension with the JIS #1 screwdriver in order to get to the screws with yellow marks because they locate deep inside the holes.
  2. Carrera Mario Copter Controller Circuit Board Replacement: adım 2, 1 resimden 1.
    • Remove the black case to access the circuit board.
    • Remove two 4.8mm screws on the circuit board with the JIS #1 screwdriver.
  3. Carrera Mario Copter Controller Circuit Board Replacement: adım 3, 1 resimden 1.
    • Gently lift up the circuit board from the black case.
    • Use a soldering iron to melt the red wire while at the same time pulling it from the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Repeat the previous procedure with the black wire.
    • Gently remove the circuit board away from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Edgar Lopez-Allende
207 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G6, Rose Fall 2017 UW Tacoma, Team S1-G6, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 285
