Giriş
The Casio FX-991EX can malfunction if the battery is discharged, even with solar power. Thankfully, replacing it is a simple job.
Neye ihtiyacın var
Remove the battery cover's screw using a Philips #0 screwdriver.
Slot the new battery into the compartment. Ensure that the positive side (with writing) faces up...
And the negative side faces the calculator's screen.
If you need to reset the calculator after this, it's SHIFT+9 > 3 > =.
Otherwise, you're ready to crunch numbers again!
7 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Just discovered during a lecture that my battery has become a spicy pillow - if you're leaving this in storage be careful and monitor it, lest it explode and/or warp the case irreparably.
I found nothing in the slot. What can i do?
