Ana içeriğe geç
Change the Presser Foot on a Sewing Machine
Neye ihtiyacın var
  1. Change the Presser Foot on a Sewing Machine, Presser Foot: adım 1, 2 resimden 1. Change the Presser Foot on a Sewing Machine, Presser Foot: adım 1, 2 resimden 2.
    • Set the sewing machine needle to the upright position by turning the balance wheel towards you.
    • Release the presser foot lever by sliding it up.
    • The presser foot will just fall out. Be ready to grab it.
  2. Change the Presser Foot on a Sewing Machine: adım 2, 3 resimden 1. Change the Presser Foot on a Sewing Machine: adım 2, 3 resimden 2. Change the Presser Foot on a Sewing Machine: adım 2, 3 resimden 3.
    • Pull the presser foot down and slide it off the peg on the machine.
    • Be careful not to break the needle.
  3. Change the Presser Foot on a Sewing Machine: adım 3, 3 resimden 1. Change the Presser Foot on a Sewing Machine: adım 3, 3 resimden 2. Change the Presser Foot on a Sewing Machine: adım 3, 3 resimden 3.
    • Grab your desired presser foot, and orient it foot-down.
    • Take the foot at an angle and slide the hole in the top of the presser foot onto the peg on the sewing machine.
  4. Change the Presser Foot on a Sewing Machine: adım 4, 2 resimden 1. Change the Presser Foot on a Sewing Machine: adım 4, 2 resimden 2.
    • Slide the presser foot lever down to lock the new foot in place.
    • Be sure to check your manual to see if you need to adjust the needle position. If it's not correctly adjusted, you may hit the needle on the presser foot and break the needle while sewing.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Brittany McCrigler
89.128 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.066 adet Kılavuz yazıldı
Bir Yorum
Tolle Anleitung, vielen Dank und wie kann man die Drehteile ersetzen wo die Fäden reinkommen? Kann ich das selbst ersetzen oder muss ein Fachmann her?
Ben - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 68
Son 30 gün: 295
Her zaman: 49,591
