Ana içeriğe geç
Charging Component on the Base Replacement
Neye ihtiyacın var
  1. Charging Component on the Base Replacement, Base: adım 1, 1 resimden 1.
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Charging Component on the Base Replacement: adım 2, 2 resimden 1. Charging Component on the Base Replacement: adım 2, 2 resimden 2.
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Charging Component on the Base Replacement, Charging Component on the Base: adım 3, 2 resimden 1. Charging Component on the Base Replacement, Charging Component on the Base: adım 3, 2 resimden 2.
    • Locate the charging component towards the bottom of the grey, plastic, phone-shaped extrusion. It is composed of two metal pieces; each is fastened by a 5mm Phillips #0 screw.
    • Remove both 5mm Phillips #0 screws to release the metal pieces.
  4. Charging Component on the Base Replacement: adım 4, 1 resimden 1.
    • Cut the black and red wires to finish removal, and then solder your new replacement component.
    • For more help on soldering, please refer to the iFixit Solder and Desolder Guide.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Han Shih
394 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S3G3
4 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 457
