Ana içeriğe geç
Chromo Noria Battery Replacement
Neye ihtiyacın var
    1. Chromo Noria Battery Replacement, Back Panel: adım 1, 3 resimden 1. Chromo Noria Battery Replacement, Back Panel: adım 1, 3 resimden 2. Chromo Noria Battery Replacement, Back Panel: adım 1, 3 resimden 3.
      • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
      • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
      FixBot'a Sor
      Yorum Ekle
    2. Chromo Noria Battery Replacement: adım 2, 1 resimden 1.
      • Carefully turn the device over.
      • Lay the back panel aside so you can see the device's parts.
      FixBot'a Sor
      Yorum Ekle
    1. Chromo Noria Battery Replacement, Battery: adım 3, 3 resimden 1. Chromo Noria Battery Replacement, Battery: adım 3, 3 resimden 2. Chromo Noria Battery Replacement, Battery: adım 3, 3 resimden 3.
      • Place your finger at the end of the tape closest to the battery.
      • Peel the tape towards the flex cables to free the battery wires.
      FixBot'a Sor
      Yorum Ekle
    2. Chromo Noria Battery Replacement: adım 4, 3 resimden 1. Chromo Noria Battery Replacement: adım 4, 3 resimden 2. Chromo Noria Battery Replacement: adım 4, 3 resimden 3.
      • Using the spudger tool, place the tool along an edge of the battery.
      • Be careful not to bend or break the battery! Batteries contain hazards materials.
      • Move the spudger around the edges of the battery to detach it from the tablet.
      FixBot'a Sor
      Yorum Ekle
    3. Chromo Noria Battery Replacement: adım 5, 1 resimden 1.
      • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
      • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Nguyen
159 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 5-6, Williams Fall 2016 Baylor, Team 5-6, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G6
3 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 851
