Ana içeriğe geç
Chromo Noria Motherboard Replacement
Neye ihtiyacın var
  1. Chromo Noria Motherboard Replacement, Back Panel: adım 1, 3 resimden 1. Chromo Noria Motherboard Replacement, Back Panel: adım 1, 3 resimden 2. Chromo Noria Motherboard Replacement, Back Panel: adım 1, 3 resimden 3.
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Motherboard Replacement: adım 2, 1 resimden 1.
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Motherboard Replacement, Battery: adım 3, 3 resimden 1. Chromo Noria Motherboard Replacement, Battery: adım 3, 3 resimden 2. Chromo Noria Motherboard Replacement, Battery: adım 3, 3 resimden 3.
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Motherboard Replacement: adım 4, 3 resimden 1. Chromo Noria Motherboard Replacement: adım 4, 3 resimden 2. Chromo Noria Motherboard Replacement: adım 4, 3 resimden 3.
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Motherboard Replacement: adım 5, 1 resimden 1.
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
  6. Chromo Noria Motherboard Replacement, Camera: adım 6, 2 resimden 1. Chromo Noria Motherboard Replacement, Camera: adım 6, 2 resimden 2.
    • Carefully detach one side of the black tape from the board.
  7. Chromo Noria Motherboard Replacement: adım 7, 2 resimden 1. Chromo Noria Motherboard Replacement: adım 7, 2 resimden 2.
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
  8. Chromo Noria Motherboard Replacement: adım 8, 2 resimden 1. Chromo Noria Motherboard Replacement: adım 8, 2 resimden 2.
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
  9. Chromo Noria Motherboard Replacement, Speaker: adım 9, 1 resimden 1.
    • Using your spudger tool, remove speaker from the backboard.
  10. Chromo Noria Motherboard Replacement: adım 10, 2 resimden 1. Chromo Noria Motherboard Replacement: adım 10, 2 resimden 2.
    • Using the spudger tool, detach the speaker from the back of the screen.
  11. Chromo Noria Motherboard Replacement: adım 11, 1 resimden 1.
    • Using a Soldering Iron, desolder both wires from the motherboard.
  12. Chromo Noria Motherboard Replacement, Motherboard: adım 12, 2 resimden 1. Chromo Noria Motherboard Replacement, Motherboard: adım 12, 2 resimden 2.
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
  13. Chromo Noria Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the three pieces of tap keeping the wires in place.
  14. Chromo Noria Motherboard Replacement: adım 14, 3 resimden 1. Chromo Noria Motherboard Replacement: adım 14, 3 resimden 2. Chromo Noria Motherboard Replacement: adım 14, 3 resimden 3.
    • Place a spudger on the small black pins on either side of the flex cables.
    • Gently push the spudger towards the back of flex cables to unlock the flex cable.
    • Remove the flex cables from their insert.
  15. Chromo Noria Motherboard Replacement: adım 15, 1 resimden 1.
    • Desolder the eight connections.
  16. Chromo Noria Motherboard Replacement: adım 16, 1 resimden 1.
    • Lift the motherboard to remove.
Sonuç
Nick Rohn
475 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-6, Williams Fall 2016 Baylor, Team 5-6, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 219
