Ana içeriğe geç
Cineyo BT-03 Device Page Button Replacement
Neye ihtiyacın var
  1. Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: adım 1, 3 resimden 1. Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: adım 1, 3 resimden 2. Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: adım 1, 3 resimden 3.
    • Remove the top (button side) rubber cover using your hands.
    FixBot'a Sor
    Yorum Ekle
  2. Cineyo BT-03 Device Page Button Replacement: adım 2, 2 resimden 1. Cineyo BT-03 Device Page Button Replacement: adım 2, 2 resimden 2.
    • Flip over the device and remove the bottom rubber cover using your hands.
    FixBot'a Sor
    Yorum Ekle
  3. Cineyo BT-03 Device Page Button Replacement: adım 3, 3 resimden 1. Cineyo BT-03 Device Page Button Replacement: adım 3, 3 resimden 2. Cineyo BT-03 Device Page Button Replacement: adım 3, 3 resimden 3.
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
    FixBot'a Sor
    Yorum Ekle
  4. Cineyo BT-03 Device Page Button Replacement: adım 4, 3 resimden 1. Cineyo BT-03 Device Page Button Replacement: adım 4, 3 resimden 2. Cineyo BT-03 Device Page Button Replacement: adım 4, 3 resimden 3.
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
    FixBot'a Sor
    Yorum Ekle
  5. Cineyo BT-03 Device Page Button Replacement: adım 5, 1 resimden 1.
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Cineyo BT-03 Device Page Button Replacement: adım 6, 1 resimden 1.
    • Gently pull apart the two sections of the device.
    FixBot'a Sor
    Yorum Ekle
  7. Cineyo BT-03 Device Page Button Replacement, Button: adım 7, 2 resimden 1. Cineyo BT-03 Device Page Button Replacement, Button: adım 7, 2 resimden 2.
    • With a Phillips #1 screwdriver, remove the two 5mm screws which attach the button mount to the plastic casing of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Cineyo BT-03 Device Page Button Replacement: adım 8, 2 resimden 1. Cineyo BT-03 Device Page Button Replacement: adım 8, 2 resimden 2.
    • Using a plastic opening tool, pry the button mount off of the plastic casing of the device.
    FixBot'a Sor
    Yorum Ekle
  9. Cineyo BT-03 Device Page Button Replacement: adım 9, 2 resimden 1. Cineyo BT-03 Device Page Button Replacement: adım 9, 2 resimden 2.
    • Using a soldering iron and iFixit’s Soldering Guide, remove the individual buttons.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Rene Klopf
487 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-3, Whitney Spring 2017 Baylor, Team 8-3, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S8G3
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 344
