Clarke Floor Sander 07012A 2012 Fan Belt Replacement
Giriş
1. adıma gitThis guide will show you how to replace the fan belt in a Clarke EZ-8 floor sander.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Adım 1 Disconnect all power cables
Dikkatli ol: adım 1 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Use a long Phillips #2 screwdriver to remove the two screws securing the belt guard:
One 1/4-20 x 18 mm screw
One 1/4-20 x 30 mm screw
Carefully tilt the floor sander onto its side, exposing the sanding drum and the dust shoe plate.
Use a Phillips #2 screwdriver to remove the four screws on the underside of the sander securing the dust shoe plate.
Remove the dust shoe plate.
For the purposes of this repair, there is no need to fully remove any of the nuts in the following steps. Just loosen them enough to allow the motor to slide back and forth.
Slide the motor along its mounting slots toward the back of the sander until the fan belt is detensioned.
3 farklı kişi bu kılavuzu tamamladı.
