Ana içeriğe geç
Clothing Ribbon Button Replacement
Neye ihtiyacın var
  1. Clothing Ribbon Button Replacement, Clothing Ribbon Button Replacement: adım 1, 2 resimden 1. Clothing Ribbon Button Replacement, Clothing Ribbon Button Replacement: adım 1, 2 resimden 2.
    • Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
    • Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
  2. Clothing Ribbon Button Replacement: adım 2, 2 resimden 1. Clothing Ribbon Button Replacement: adım 2, 2 resimden 2.
    • Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
    • If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
  3. Clothing Ribbon Button Replacement: adım 3, 3 resimden 1. Clothing Ribbon Button Replacement: adım 3, 3 resimden 2. Clothing Ribbon Button Replacement: adım 3, 3 resimden 3.
    • Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
    • Do not sew the pocket with the ribbon end in it closed.
    • Sew the ribbon in place.
  4. Clothing Ribbon Button Replacement: adım 4, 3 resimden 1. Clothing Ribbon Button Replacement: adım 4, 3 resimden 2. Clothing Ribbon Button Replacement: adım 4, 3 resimden 3.
    • Backstitch to hold the stitches in place.
    • Lift the presser foot and remove the garment from the sewing machine.
    • Clip any threads.
  5. Clothing Ribbon Button Replacement: adım 5, 3 resimden 1. Clothing Ribbon Button Replacement: adım 5, 3 resimden 2. Clothing Ribbon Button Replacement: adım 5, 3 resimden 3.
    • Thread the ribbon through the button coming up from behind, over the spoke in the middle, and back down through the second hole.
  6. Clothing Ribbon Button Replacement: adım 6, 3 resimden 1. Clothing Ribbon Button Replacement: adım 6, 3 resimden 2. Clothing Ribbon Button Replacement: adım 6, 3 resimden 3.
    • Pull the ribbon taught.
    • The button should be facing with the backside out.
    • Fold the button and ribbon back over, so that the other side of the button is facing out.
    • Leave just enough ribbon to tuck into the little pocket. Clip all excess ribbon.
  7. Clothing Ribbon Button Replacement: adım 7, 2 resimden 1. Clothing Ribbon Button Replacement: adım 7, 2 resimden 2.
    • Fold the free end of the ribbon, tucking it into the little pocket, in the same manner as the first.
    • Overlap the two ends of the ribbon so that they sit directly on top of one another.
    • Sew directly over the seam, closing the little pocket.
    • This seam should catch both ends of the ribbon between the two layers of the pocket.
  8. Clothing Ribbon Button Replacement: adım 8, 3 resimden 1. Clothing Ribbon Button Replacement: adım 8, 3 resimden 2. Clothing Ribbon Button Replacement: adım 8, 3 resimden 3.
    • Backstitch to hold the seam in place.
    • Remove the garment from the sewing machine.
  9. Clothing Ribbon Button Replacement: adım 9, 2 resimden 1. Clothing Ribbon Button Replacement: adım 9, 2 resimden 2.
    • Clip any threads.
    • Admire your handiwork.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Brittany McCrigler
90.629 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
125 Üyeler
24.046 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 62
Her zaman: 3,521
