Ana içeriğe geç
Coby KYROS MID7125 Screen Replacement
Neye ihtiyacın var
  1. Coby KYROS MID7125 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby KYROS MID7125 Screen Replacement: adım 2, 3 resimden 1. Coby KYROS MID7125 Screen Replacement: adım 2, 3 resimden 2. Coby KYROS MID7125 Screen Replacement: adım 2, 3 resimden 3.
    • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger.
    • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
    • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
    • Desolder fifth ribbon cable with soldering station.
    • If soldering is new for you, then follow this useful guide on soldering and desoldering connections.
  3. Coby KYROS MID7125 Screen Replacement: adım 3, 3 resimden 1. Coby KYROS MID7125 Screen Replacement: adım 3, 3 resimden 2. Coby KYROS MID7125 Screen Replacement: adım 3, 3 resimden 3.
    • Desolder 2 speaker wires
    • Desolder Battery
    • Desolder antenna wire
    • Disconnect all wires you desoldered
  4. Coby KYROS MID7125 Screen Replacement: adım 4, 1 resimden 1.
    • Desolder the microphone wire
    • Disconnect the wires you just desoldered.
  5. Coby KYROS MID7125 Screen Replacement: adım 5, 1 resimden 1.
    • Remove 4 screws that connect the motherboard to the device.
  6. Coby KYROS MID7125 Screen Replacement: adım 6, 1 resimden 1.
    • Take off motherboard by lifting off right hand side and pulling sideways.
  7. Coby KYROS MID7125 Screen Replacement: adım 7, 2 resimden 1. Coby KYROS MID7125 Screen Replacement: adım 7, 2 resimden 2.
    • Remove 4 screws on corners of the digitizer and lift off.
  8. Coby KYROS MID7125 Screen Replacement: adım 8, 2 resimden 1. Coby KYROS MID7125 Screen Replacement: adım 8, 2 resimden 2.
    • Now that the digitizer is disconnected from the screen you can replace the screen.
    • Place the screen face down in front of you facing downward and apply pressure with your thumbs around the outside of the glass to remove the screen.
    • Next, replace with your new screen and follow steps in reverse order to reassemble.
Sonuç
Nicole Connelly
1 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 337
