Ana içeriğe geç
ColecoVision Controller Port Replacement
Neye ihtiyacın var
  1. ColecoVision Controller Port Replacement, Controller Port: adım 1, 1 resimden 1.
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Controller Port Replacement: adım 2, 2 resimden 1. ColecoVision Controller Port Replacement: adım 2, 2 resimden 2.
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Controller Port Replacement: adım 3, 2 resimden 1. ColecoVision Controller Port Replacement: adım 3, 2 resimden 2.
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
  4. ColecoVision Controller Port Replacement: adım 4, 2 resimden 1. ColecoVision Controller Port Replacement: adım 4, 2 resimden 2.
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Controller Port Replacement: adım 5, 3 resimden 1. ColecoVision Controller Port Replacement: adım 5, 3 resimden 2. ColecoVision Controller Port Replacement: adım 5, 3 resimden 3.
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
Sonuç
Bobby
380 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 841
