Ana içeriğe geç
ColecoVision Power Switch Replacement
Neye ihtiyacın var
  1. ColecoVision Power Switch Replacement, Power Switch: adım 1, 1 resimden 1.
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Power Switch Replacement: adım 2, 2 resimden 1. ColecoVision Power Switch Replacement: adım 2, 2 resimden 2.
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Power Switch Replacement: adım 3, 1 resimden 1.
    • Remove the two 15 mm screws holding the casing in place using the Phillips #1 screwdriver.
  4. ColecoVision Power Switch Replacement: adım 4, 2 resimden 1. ColecoVision Power Switch Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 15mm screws on the motherboard.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Power Switch Replacement: adım 5, 1 resimden 1.
    • Flip the motherboard over.
    • Using a soldering iron, carefully desolder the power switch from the motherboard.
    • Refer to this soldering technique guide for reference.
  6. ColecoVision Power Switch Replacement: adım 6, 1 resimden 1.
    • Wait for power switch to cool down.
    • Turn the motherboard over upright.
    • Carefully lift up the power switch to completely remove it from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bobby
380 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 1,671
