Ana içeriğe geç
Comfort Zone CZ6C Motor Replacement
Neye ihtiyacın var
  1. Comfort Zone CZ6C Motor Replacement, Motor: adım 1, 3 resimden 1. Comfort Zone CZ6C Motor Replacement, Motor: adım 1, 3 resimden 2. Comfort Zone CZ6C Motor Replacement, Motor: adım 1, 3 resimden 3.
    • Make sure to unplug the Comfort Zone CZ6C before replacing the motor. This will prevent the risk of electrocution.
    • Unscrew the main housing screw located right above the main switch using a Phillips screwdriver.
    • Then use gentle force to remove the main housing door.
    • Remember to keep track of your screws!
  2. Comfort Zone CZ6C Motor Replacement: adım 2, 3 resimden 1. Comfort Zone CZ6C Motor Replacement: adım 2, 3 resimden 2. Comfort Zone CZ6C Motor Replacement: adım 2, 3 resimden 3.
    • Unscrew the two adjacent housing screws to free the motor cage from the housing.
  3. Comfort Zone CZ6C Motor Replacement: adım 3, 3 resimden 1. Comfort Zone CZ6C Motor Replacement: adım 3, 3 resimden 2. Comfort Zone CZ6C Motor Replacement: adım 3, 3 resimden 3.
    • Remove the motor cage from the fan housing.
  4. Comfort Zone CZ6C Motor Replacement: adım 4, 2 resimden 1. Comfort Zone CZ6C Motor Replacement: adım 4, 2 resimden 2.
    • Unscrew the two adjacent motor cage screws to free the motor
  5. Comfort Zone CZ6C Motor Replacement: adım 5, 3 resimden 1. Comfort Zone CZ6C Motor Replacement: adım 5, 3 resimden 2. Comfort Zone CZ6C Motor Replacement: adım 5, 3 resimden 3.
    • The motor is now free to be replaced.
    • If the motor will not move out of its now freed state you can use WD-40 to loosen it
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Gage Wilson
217 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 68
Her zaman: 5,577
