Ana içeriğe geç
Comfort Zone CZ6C Switch Replacement
Neye ihtiyacın var
  1. Comfort Zone CZ6C Switch Replacement, Switch: adım 1, 3 resimden 1. Comfort Zone CZ6C Switch Replacement, Switch: adım 1, 3 resimden 2. Comfort Zone CZ6C Switch Replacement, Switch: adım 1, 3 resimden 3.
    • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
    • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
    • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
    FixBot'a Sor
    Yorum Ekle
  2. Comfort Zone CZ6C Switch Replacement: adım 2, 2 resimden 1. Comfort Zone CZ6C Switch Replacement: adım 2, 2 resimden 2.
    • Remove the plastic cover on the switch by pulling it apart from the the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. Comfort Zone CZ6C Switch Replacement: adım 3, 1 resimden 1.
    • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
    • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
    • Disconnect the gray power wire from the switch by desoldering the connection.
    FixBot'a Sor
    Yorum Ekle
  4. Comfort Zone CZ6C Switch Replacement: adım 4, 2 resimden 1. Comfort Zone CZ6C Switch Replacement: adım 4, 2 resimden 2.
    • Cut the green and yellow wire as close to the switch connection as possible.
    FixBot'a Sor
    Yorum Ekle
  5. Comfort Zone CZ6C Switch Replacement: adım 5, 3 resimden 1. Comfort Zone CZ6C Switch Replacement: adım 5, 3 resimden 2. Comfort Zone CZ6C Switch Replacement: adım 5, 3 resimden 3.
    • Strip the green and yellow wire about two centimeters from where it was just cut.
    FixBot'a Sor
    Yorum Ekle
  6. Comfort Zone CZ6C Switch Replacement: adım 6, 3 resimden 1. Comfort Zone CZ6C Switch Replacement: adım 6, 3 resimden 2. Comfort Zone CZ6C Switch Replacement: adım 6, 3 resimden 3.
    • Unscrew the switch from the back panel and remove it.
    FixBot'a Sor
    Yorum Ekle
  7. Comfort Zone CZ6C Switch Replacement: adım 7, 3 resimden 1. Comfort Zone CZ6C Switch Replacement: adım 7, 3 resimden 2. Comfort Zone CZ6C Switch Replacement: adım 7, 3 resimden 3.
    • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Abundis
169 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G5
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 2,775
